Question about Imperial 7 Person Hot Tub Spa
How do I reset error code on imperial hottub..?
Flo code is showing how do I reset it?
  • 1,631 Answers
Flo code is not a resettable message. That means you have a problem. Is it flashing (interactive with temp) or is it solid (only the Flo Code) ?
Both of these are two different problems, and they have to be corrected before the message will clear.
Try cleaning the filter, or if it is older than 18 months, replace it.
Posted on Jan 27, 2014
How do you reset an imperial hot tub flo control panel? this one is 10 yrs old.
shut it off entirely .. unplug..reconnect and power it back up reset all settings..
Nov 21, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Need to know wire gage
Copy following link:
http://waterheatertimer.org/Color-codewire.html
Add comment and say if each is wired separately, and how many volts.
Apr 13, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Hot tub won't heath up cal spa
Could be many things, please explain further.
Apr 11, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Capacitors for an aqua flo master xp 2 pump for a hot tub
What about the capacitors?
If you need some there are many stockists. If you're in the UK I may have some available.
Regards,
Ian.
Mar 29, 2010 | Pool & Spa
What do i do if i have put to much chlorine in my hot tub
You can drain some of the water to a sewer line or get chlorine netrulizer at your local pool store and add that.
Mar 09, 2010 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Flo word on panel nothing else works
'Flo' means that there's insufficient flow of water through the heater, or non at all.
1) Check the water level - top up if low.
2) Ensure that all jets are open and flow water - if they don't you may have a pump issue.
3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
Regards,
Ian.
Mar 06, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Im tryin to tighten a hot tub tap that has no acsess panel to it . is there a way to tighten tap without cuting into wall ?
Without seeing the positioning it's hard to say. It should be possible, I know from my own experience that some unions can be incredibly difficult to access but I always find a way.
If you cant get access to it, would it be possible to lift the hot tub onto its side and gain access through the floor?... It would be harder but much neater than cutting the cabinet.
Regards,
Ian.
Feb 16, 2010 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Imperial 7 Person Hot Tub Spa Logo
150 people viewed this question
Top Imperial 7 Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Imperial 7 Pool and Spa Expert? Answer questions, earn points and help others
