Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
How do you reset an imperial hot tub flo control panel? this one is 10 yrs old.
Was working fine went out next am and the flo code and fc is showing..
  • 3,103 Answers
Shut it off entirely .. unplug..reconnect and power it back up reset all settings..
Posted on Jan 10, 2014
3 Suggested Answers
  • 37 Answers
SOURCE: reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Posted on Oct 11, 2009
Testimonial: "Thank you!"
adamh294
  • 310 Answers
SOURCE: my hot tub control panel keeps showing OH and the
It sounds like your circulation pump is not keeping up with the heater. Check for debris in the pump impeller. If this is 24 hour circulation pump, it is probably failing. New units are about $200 US
Posted on Oct 28, 2010
Control panel and no pumps
do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
Jan 05, 2014 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
How do I reset error code on imperial hottub..?
Flo code is not a resettable message. That means you have a problem. Is it flashing (interactive with temp) or is it solid (only the Flo Code) ?
Both of these are two different problems, and they have to be corrected before the message will clear.
Try cleaning the filter, or if it is older than 18 months, replace it.
Nov 21, 2013 | Imperial 7 Person Hot Tub Spa
My hot tub is leaking from one of the pumps. how do i change the pump?
Sounds like you need a new Mechanical Seal for the wet end. Pretty simple job to change the seal kit.
It is also a lot cheaper to do that than purchase a new pump.
US Parts Center
Apr 19, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My hot tub top control is flashing SPA6,and hot tub is not heating up.
Here is a link for you to resource that error code.
click that link and scroll through them until you find your error code.
Rod
US Parts Center
Aug 19, 2012 | Jacuzzi Pool & Spa
J-300 won't heat. FLO readout
FLO = It typically for a Flow Switch or pressure switch (heater is deactivated. Pump may also be deactivated).
It is most likely a flow/pressure switch failure.
Before you buy a replacement try running the spa with out the filter cartridge - Checking if dirty cartridge is the issue. Also check that all gate valves are all the way open & locked.
Jan 05, 2012 | Jacuzzi Home
I just bought my hot tub, it shows ''FLO'' on the panel when i turn it on. I did every thing they say on the panflet but it still doesn`t work. Anything else i should do??
The problem is that the flow switch for your water heater is indicating no flow. Therefore your water heater will not operate. Without proper water flow your heater will burn up. Check that your valves are open. Check that your pump is running. Check that your filters are properly installed and not restricting flow. Check the wiring to your flow switch and make sure the flow switch operating properly (i.e. put a ohm meter across the contacts and see if you have continuity when the switch closes).
Sep 18, 2010 | Apollo Pool & Spa
Getting mostly hot from Exacttemp control 4 yrs. old
Moen's website has PDF's available for download on their site. These have pictures and show you how to adjust the temperature control for your model.
http://www.moen.com/shared/pdf/instruction_sheets/ins1282b.pdf
Jun 16, 2010 | Moen & One Handle Tub & Shower Faucet
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My Raypak versa gas heater for my hot tub will not heat the tub more then 96F, temp control is turned all the way up, just stated doing this, it was fine for a year, thanks
Water flo through the heater is too fast and the water can't get hot enough. Your by-pass valve is stuck closed and you need to open your water header and check it out. Or you may have an external by pass that need's to be opened 10-20%. This will be a valve between the inlet and outlet water pipes going to the heater. Good luck and HAPPY NEW YEAR.
Dec 24, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
107 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
