Question about Home
NEED A RUBBER SEAL
EPC-807
Peugeot 807 faults
cheap china batteries, or duracell.
huh?
if good battery makes.
then the fob is bad, buy a new fob.
yes, the can go bad, seen many do this.
even got wet, ?
i buy the rubber covers for mine so they stay dry. (good uses of china parts, a cover) only use IMO.
May 25, 2014 | 2007 Peugeot 807 2.0
Instructions
Here is the manual 8Qt Digital Pressure Cooker Pressure Cookers Elite Platinum MAXI MATIC...
It is down at the bottom center of the page "Download" kind of hard to see
Mar 04, 2014 | Maximatic Maxi-Matic - Elite Platinum...
Audi epc light
What ,year audi and model? EPC LIGHT PO299. let me see if i can find out with out year and model.
okay, if your car has turbo then this is correct, po299 low boost.
this may be caused by a bad diverter valve on the turbo, if you remove it and look ay diaphram for any cracks or splits in rubber, if it is then replace it ,check for an update valve at dealer.
there are other thing that can cause this code but start with that. a loose hose for the turbo can cause this code or bad turbo or clogged converter, or oil sulge problem.
Jun 29, 2013 | Cars & Trucks
I need an instruction book for the Elite Platinum Electric Pressure Cooker Model # EPC807
This was pretty hard to find, but I located it just for you!
Here it is, you will need adobe reader to view it, but you most likely have that already, if not get it from get.adobe.com/reader/:
http://micromatikal.dlinkddns.com:8000/cust/EPC-807.pdf
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 22, 2010 | Kitchen Appliances - Others
The gears r slipping when temp gets hot just put flid in yesterday does this mean I need new transmission
You may get luck and you may just have a 1-poor line pressure rise due to leaking boost valve, 2-clogged EPC filter screen, 3-failing EPC solenoid, 4-or worst case: leaky seals throughout. First two without removing trans. Seal restorer may fix last problem, but probably R&R. Also try a transmission flush with BG brand products to clean the EPC filter screen and then service the transmission by replacing the boost valve, transmission oil and filter.
Thank you for using fixya and good luck. This should keep you from replacing the transmission if the clutch packs are not to badly worn or damaged which can be inspected when the transmission pan is dropped by the amount of clutch particles collected in the transmission pan.
May 09, 2010 | 2004 Oldsmobile Alero
Home Logo
52 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
