Question about HP OfficeJet 7310 All-In-One InkJet Printer
Fax function will not work
When I push the start fax button, the machine acts as if it is scanning, the display says the number is being dialed, then after a few seconds, a page is printed that says no answer
4 Suggested Answers
SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters Information It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured. From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
  3. Enter the parameter ____ on the key board and press the Check Mark.
    • 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    The screen will read Cfg param val: 26
  4. Enter in the value ____ and then press the Check Mark .
    • 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Screen will read Test -001+
  5. Press the Reset button until you get back to Ready *
Posted on Oct 13, 2008
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
SOURCE: machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Posted on May 26, 2010
How do you fax papers?
Make sure the fax machine is properly installed with an operational phone line. Put the papers in the fax machine (ensure they are facing the proper direction). Dial the number you want to fax to, ensuring you have the proper codes for external lines and long distance calls if required. Push the start button. The machine will scan your documents, dial the number, and send the faxed documents when a connection is made.
Mar 11, 2015 | Office Equipment & Supplies
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
How do I set and save a fax number as a speed dial
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON%20CFX-L4000.pdf
Here is a transcript:
Storing Numbers for One-Touch Speed Dialing
Your Canon fax can store up to 120 phone numbers: up to 20 of your most frequently used numbers can be stored for One-Touch Speed dialing, and an additional 100 numbers can be stored for Coded Speed Dialing.
1. Press SET and DATA REGISTRATION
The display will show:
DATA REGISTRATION
1. SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
3. Use the search buttons (up and down symbols) to select a One-Touch Speed Dialing button between 01 and 20.
1-TOUCH SPD DIAL
[1...7]
??¢ You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
??¢ If a number is already stored at the button you select, that number appears.
??¢ If the button you select is registered for Group Dialing, GROUP DIAL appears.
4. Press SET twice. Use the numeric buttons to enter the fax number you want to store.
TELEPHONE NUMBER
TEL =
??¢ Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
??¢ If you want to clear a number or a mistaken entry, press CLEAR.
??¢ To enter a pause in the number, press PAUSE one or more times
Sep 22, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I save a number
You can download the User Manual from here (temporary link): http://dl.dropbox.com/u/1322442/CANON CFX-L4000.pdf
DATA REGISTRATION
1 .SPEED DIAL SETUP
2. Press SET twice.
1-TOUCH SPD DIAL
01
1-TOUCH SPD DIAL
[1...7]
• You can also do this by pressing FUNCTION, then pressing the One-Touch Speed Dialing button, then pressing FUNCTION again.
• If a number is already stored at the button you select, that number appears.
• If the button you select is registered for Group Dialing, GROUP DIAL appears.
TELEPHONE NUMBER
TEL =
• Press SPACE to enter spaces between numbers. (Spaces are optional and are ignored during dialing.)
• If you want to clear a number or a mistaken entry, press CLEAR.
• To enter a pause in the number, press PAUSE one or more times
Aug 19, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Speed dial list
***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
HP OfficeJet 7310 All-In-One InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
