Question about ViewSonic PJD6241 3D DLP Projector
Power light blinks blue - ViewSonic PJD6241 3D DLP Projector
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Fan noise and blinking blue power light
green=power in motherboard.
blue=stand by.
yellow=memory powerd
Jun 13, 2013 | Gateway GT5622 PC Desktop
Wi-max light deep blue Power and charging and battery light blue-white HDD light blinking
Make sure your dvd rom does not contain a disk.
Your system checks your dvd rom drive first for a bootable disk.
A blinking HDD light is normal during boot up.
Feb 06, 2013 | Toshiba Satellite Computers & Internet
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
What does the blue blinking light at the very bottom, under the blue power button indicates?
According to the Dell 531 owners manual:
"Drive activity light-
blue light - A blinking blue light indicates the computer is reading data from or writing data to the SATA hard drive, CD, DVD or HDD."
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
Safe to ignore. It will blink even when the computer appears to be idle.
Aug 15, 2011 | Dell Inspiron 531s Desktop Computer
Tv turns on for a few seconds then shuts off and the blue power light blinks.
Mine never turned on but the blue power light would blink.I disconnected the upper y buffer and got light on the bottom half of screen and the blinking stopped.I have the upper board on order and I think this will fix my problem.There is a blink code somewhere,just count how many blinks.Start pulling connectors from power supply and when it quits blinking you've found the one,could also be the power supply with bad cap.
Jul 14, 2011 | Hitachi Ultravision P50S601 50 in. Plasma...
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
ViewSonic PJD6241 3D DLP Projector Logo
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
