Question about Trust Maxtrack Wireless Rf Wireless Optical 1000 Dpi Aa Pc Mac
Mouse doesn't connect - Trust Maxtrack Wireless Rf Wireless Optical 1000 Dpi Aa Pc Mac
Mouse Problem
First, let's see if the computer is recognizing the mouse. Unplug the mouse, restart the computer, and then re-plug the mouse. Typically, the computer, in the bottom right side of the screen will attempt to re-establish connection to the mouse.
If it does not, then re-downloading the driver for the mouse (if a disc was not provided with it) will help the computer recognize the mouse and the connection.
Hope that helps.
May 18, 2013 | Computers & Internet
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
My mouse doesn't work on my laptop
for some mouses, there is an installation cd and you should install before you connect your mouse in usb slot.
If there is no installation CD then the wire connecting mouse to usb must have been ruptured
May 01, 2012 | Sigma Mouse
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
I have a compucessory wireless mouse and keyboard. Mouse model 40918. My mouse just stopped working this morning. How do I get it to reconnect?
check the batteries on the mouse
usually on the underside of a mouse possibly under a plastic sticker rub your fingernail across the top to locate a small (phillips screw) star screw make sure they are connected you can do this by spinning them around and fully charged
hope this heps
Oct 25, 2011 | Compucessory Wireless Optical Mouse...
How do i re-connect my wireles mouse? I can not find directions and I am away from home!!
Hello there.
To reconnect your wireless mouse here is what you should do:
1. Be sure your computer is turned on.
2. Connect the receiver with the USB connector.
3. Be sure you have batteries in your mouse. The synchronization will start automatically.
4. If synchronization doesn't start automatically, press the connect button on the receiver then press the connect button on the bottom side of the mouse for ten seconds.
Thanks for using Fixya!
Jun 25, 2011 | Belkin F8E874-APL Wireless Optical Mini...
The mouse will not move the arrow
batteries new? usb cvable plugged in the computer? have tou tried to connecrt the mouse to the receiver as well? there is usually a button on the mouse and the receiver to connect the 2 together, press the one on the receiver first, then the one on the mouse.
Nov 18, 2009 | GE Wireless Optical Mouse
Jumping mouse cursor
Elsamma, If you are positive keeping the cable stationary prevents the problem try this: Try holding the mouse connector stationary and wiggle the cable. If the problem occurs then the connection between the mouse connector/cable is defective, due to the low value of this mouse the fix would typically be replacing rather than repair. If that doesn?t work try wiggling the mouse connector where it plugs into the PC. If this causes the problem to reappear then either your mouse connector or the PC socket is damaged. Try another mouse and if the problem goes away, again the fix would be to replace the mouse. If a new mouse doesn?t fix the problem then there is a good chance the PS2 connector is damaged. At this point I would purchase a USB mouse which should solve your problem Let us know how things go and if you need any more assistance.
Jul 11, 2007 | Logitech -9536890403 Mouse
Trust Maxtrack Wireless Rf Wireless Optical 1000 Dpi Aa Pc Mac Logo
Top Trust Computers & Internet Experts
micky dee
Computer Links
Robin Hill
Robin Hill
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
