Question about Yamaha YPT400 61 Key Portable Keyboard with Touch Sensitive Keys
Yamaha ygp 635
My keyboard light wont go on
My keyboard wont turn on. I've tried everything. Please help me.
Assuming the power supply is the correct type, the next likely thing to go wrong is the socket on the keyboard. Can you get it to light up if you wobble the connection to the keyboard. If it comes on momentarily then the socket is faulty and will need to be repair. A relatively simple soldering job if you are not competent in doing the job your local music store should be able to help. I do a lot of these in UK cost around 30.00GBP including parts.
Oct 12, 2014 | Yamaha Portable Keyboard
My yamaha keyboard wont make a noise when i press on the keys. the volume is up and everything but it still wont make a noise :( but i dont want to send it out to be repaired please help me.
This may sould dumb, but did you check the Headphone jack? If the 1/4" adapter for 1/8" may be left in the port, like on my keyboard. I took it out and sound came on. Lame, I know, but . . . .
Mar 10, 2013 | Yamaha Full-Size Keyboard
Hi My yamaha PSR S500 keyboard is not turning on! I bought a new adaptor but it still wont come on
Check that your adapter is a 12VDC with a current rating of at least 1 amp (1000ma) AND that the center pin of the connector is the POSITIVE.
Feb 07, 2011 | Yamaha PSR-S500 Digital Keyboard
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha musical keyboard makes mono tone when turned on?
Check that you have the exact power adapter for the unit.
Dec 03, 2009 | Music
Lcd only showing half on yamaha 600 keyboard
i assume you mean that, only half of your LCD is functional.
if this is the case, it culd be one or more of many things.
the most likely, is that the screen is cracked. this may be an "internal fracture" and will not be visible (you wont see cracks).
another, however, more unlikely reason is that the ribbon cable is partly detached. if this is so, you could get inside the keyboard your self (which WILL void your warranty).
this is rather difficult, and there is a high risk of damaging other aspects of the keyboard in the proses.
if it is still under warrenty, call up yamaha tech support and see if they are able to do anything for you.
if you are no longer under warranty, or would rather pay: find a local music (or electronics) store, and have them look at it.
Aug 22, 2009 | Yamaha Full-Size Keyboard
Yamaha 9000pro froze and after restarting doesnt do anything anymore the only thing that happens when i swiths it on is that the display lights up , but it wont start up completely. could it be a harddrive...
First thing is to Isolate the keyboard and then take out the Hard Drive and restart the keyboard. If that doesn't work then that's the first problem eliminated. You can do a Factory Reset on the keyboard. I'm not too sure on this keyboard but mostly it's Turn on the keyboard and simultaniously hold a certain button(s) or Key(s) [normally at the top end]. This info will be in the Manual.You could look at the troubleshooting page in the Manual also. Other than that at this time I can't help any further.......Good luck!
Dec 31, 2008 | Yamaha Full-Size Keyboard
Yamaha psr230 keyboard wont turn on
I was bird so I got on my yamaha won"t I c it and it don"t turn on
Oct 19, 2008 | Yamaha Full-Size Keyboard
Yamaha YPT400 61 Key Portable Keyboard with Touch Sensitive Keys Logo
26 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
