Question about Canon Cameras
Card locked. Downloaded many times to my laptop. Forgot card was in for a couple of days. Now when I put the card back in my Canon A620, it says "Card Locked".
  • Sharon Ash
    Sharon Ash Nov 22, 2013
    Solution worked. Have had this camera for six years and just noticed the locking device on the card. Thanks for such quick response.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
What kind of card is it? Some different cards have a physical miniswitch on the side. Maybe you moved it by mistake to the 'lock' position when handling it. Also, some cameras have a lever inside the slot where the card fits, this lever locks/unlocks the physical switch I was talking about, and it can sometimes move to an undesired position, namely always locking the card. Look into the slot and try moving gently any lever/protusions.
Posted on Nov 22, 2013
  • 8 Answers
SOURCE: canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Posted on Dec 19, 2008
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
robmcd27
  • 423 Answers
SOURCE: Locked memory card
Your camera is telling you the lock switch on the card is locked.
Take the card out of your camera and look on the side. There will be a little switch. One side of the switch says locked and the other side says unlocked. Move the switch from the locked position to the unlocked position and it will work for you.
Rob
Posted on Mar 09, 2009
t00nz
  • 4738 Answers
SOURCE: Photo card locked and can not take pictures.
There should be a tiny slide switch on the side of the card. Merely slide this switch to the other "unlocked" position.
Posted on May 28, 2009
iwctoys
  • 126 Answers
SOURCE: Canon PowerShot A620 says no memory card when
Your camera has a board with the SD card slot board and electronics to record and retrieve images. This board can be replaced and should cost about $100 to repair.
Posted on Jul 03, 2009
Canon A620 LCD shows "memory card locked" for each card I insert
This worked for me!  I have the Canon Powershot SD780 IS and although my card WAS NOT locked, the camera "malfunctioned" and the switch in the camera needed to be gently pushed back IN, not DOWN on my specific camera type.  This is great, I was just going to go out and buy another camera today!  Thanks for the post Stephan!
Nov 10, 2009 | Canon PowerShot A620 Digital Camera
Card locked
Hi...
If your card is locked try to remove the card. See if there is a small button there and slide it to unlock the card. Put your card back to your DG cam.
Good luck.
Regards
PCmania
Sep 01, 2009 | Canon PowerShot A620 Digital Camera
Put new SanDisk 4GB card in Canon A620 and get Memory Card Error
The A620 came out in 2005, before the SDHC (high capacity) protocol had been introduced. The A580 came out in 2008 and is compatible with the SDHC protocol. The A620 is only compatible with the SD protocol, and maximum capacity under this protocol is 2MB.
Aug 27, 2009 | Canon PowerShot A620 Digital Camera
Hi my canon A620 camera - I have purchased two 4gb memory cards and both say they are locked. Is this the camera, are the cards too big a memory. thanks for your help.
Canon doesn't typically publish information regarding the top capacity for memory cards, especially since new cards come out all the time and they'd have to continually rewrite their manuals.
I would, however, suggest getting a couple of 2gb cards instead of a single 4gb card. Not only is there less of a question of compatibility with 2gb cards, but if you misplace one, you still have a backup. A 2gb card will hold several hundred shots at full resolution and the lowest compression, so you won't have to worry about running out of space.
Hope this helps!
Aug 21, 2009 | Canon PowerShot A620 Digital Camera
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Memory card error
The memory card could be too big. Some camera's can only use a certain size memory card. You will have to check your manual to see what the specifications for your memory cards. Hope this helps.
Jul 16, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 says no memory card when there is a memory card installed. Tried two different cards and both not working. Card is not full or locked. Card door closes all the way. Owner's manual's...
Jul 02, 2009 | Canon PowerShot A620 Digital Camera
Locked memory card
Rob
Mar 09, 2009 | Canon PowerShot A620 Digital Camera
Cameras Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
