Question about Zojirushi Stainless Steel Food Jar - SWFBE75
How to use the top of Jar for what?
There is the hole on the top that I don't know how to put what or use for?
  • 2,113 Answers
I researched and it appears that the hole is for a straw
Posted on Nov 21, 2013
What's the procedure of bleeding hydraulic disc brake of a motorcycle
Hi,,best to get a good self bleeding tube, a small jar, and a spanner for the bleed nipple on the brake caliper,and the right brake fluid for your bike,
undo resurver cap,then put the bleed tube on the bleed nipple,put the other end into the jar,then put about a inch of brake fluid into the jar so it covers the end of the tube,then fill the brake resurver up near the top,then open the bleed nipple on the caliper only enougth to let the fluid come out,now pull the brake leaver in slowly,you should now see fluid going down the tube into the jar(if it dosnt open the blead nipple a bit more),if you can see fluid going down the tube into the jar,let brake leaver out slowly,keep repeating the prosedure untill you see all air bubbles gone or if you want to replace all the fluid untill you see the clean fluid coming through,dont forget to keep the fluid in the resurver topped up other wise you will draw air bake into the system and will have to start all over again,if you have two discs on the front do the one firthest away from the resurver first,when you have finnished the bleeding make shore the fluid thats in the resurver is in between the min and max marks,hope this helped a bit.
Aug 15, 2016 | Cars & Trucks
Gnats in bedroom
Gnat trap apple cider vinegar or any type of vinegar just add a fruit or something to attract insects put vinegar in a jar poke holes in the top so they can enter they are very attracted to the vinegar and wont leave the jar or any other contraption you make place it in a gnat populated area and throw jar away after you catch alot perferably more then one trap till you get all of those pesky things hope this helps
Jan 20, 2014 | Kyocera Cell Phones
Gnats house
gnat trap apple cider vinegar or any type of vinegar just add a fruit or something to attract insects put vinegar in a jar poke holes in the top so they can enter they are very attracted to the vinegar and wont leave the jar or any other contraption you make place it in a gnat populated area and throw jar away after you catch alot perferably more then one trap till you get all of those pesky things hope this helps
Jan 20, 2014 | Nokia 6101 Cellular Phone
How to open/repair Logitech S100 speakers for the power cord replacement?
first open the net over the speaker...top bottom corner there is a hole then in this hole put a strength stick pressure heavy by side..then it will show u crack by this crack u have to open it!!remind there is no screw in s-100 logitech speaker!!Thanx!
Feb 07, 2013 | Logitech S100 Computer Speakers
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
95 villager has right front brake drag, replaced the brakes, rotor, hoses, calipers and installed a used abs modulator. orginally it was right front left rear issues, not it is only right front
This type of problem can occur if the wrong fluid has been used at some earlier stage,in which case all seals need to be replaced along with master cylinder overhaul.
Jun 19, 2011 | 1995 Mercury Villager
Wet phone model # SGH-a717
I don't really understand what is being asked here. Are you saying you were **** and dropped your phone in the toilet and it is now wet? The best thing to do is remove the battery right away. Get a big jar, fill it with rice. Put the phone and the battery in the rice filled jar. The rice will absorb all moisture quickly, hopefully saving the water-logged electronics. Keep the phone in the jar for 24 to 48 hours, let it really dry out. Try to put the battery in the phone and start it up. If NOTHING happens, maybe the battery is dead. Try charging it. If still NOTHING happens, I think that you may have water-logged your phone and it is beyond repair. Try using your home-owner's insurance, if you have it, and claim your phone was stolen. Maybe they will give you money to buy a new phone.
Oct 27, 2009 | Samsung SGH-a717 Cellular Phone
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
I recently bought a sciphone i9++ and i dont know how to install java...Can yu give me the step by step procedure on this
You don´t need to install java. It is already installed.
Just put Java applications (jar files) into the Java folder and run them by double clicking.
Oct 18, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do I get a stuck light bulb out of the refrigerator?
Simple, use a hair dryer (on high heat) on the base of the bulb for a few seconds. The bulb will come out easy. Cold expands and is what made it stick. This has worked every time for me.
Mar 26, 2008 | GE Hotpoint Top-Freezer Refrigerator
Zojirushi Stainless Steel Food Jar - SWFBE75 Logo
625 people viewed this question
Top Zojirushi Home Experts
john h
Tom Chichester
Are you a Zojirushi Home Expert? Answer questions, earn points and help others
