Question about HP Pavilion Computers & Internet
Have not been able to download from "utorrent" for days. says waiting to log in and when I do tests it says the forward port is not working, however should download. it does not. can you help please. Lyn
  • 8 more comments
  • Lynette McCullough
    Lynette McCullough Nov 21, 2013
    Hello Aaron. Many thanks for your info, however I am a klutz in reltion to IT issues. Can you guide me please.
  • Aaron Smith
    Aaron Smith Nov 22, 2013
    Well first things first is the message something about DHT Waiting To Log In?
    Lynette McCullough Nov 22, 2013
    yes correct
    Yes, I have uninstalled Utorrent at least 3 times endeavouring to fix the problem. will do now. Don't worry about time issue. I will keep checking.
    utorrent has been uninstalled
  • Aaron Smith
    Okay I will get back to you some time today! I am at work and don't have time to look up the necessary info, but there are some files I will have you delete, then we will reinstall uTorrent after they are gone and it should fix your issue.
    Thank you Aaron
  • Aaron Smith
    Aaron Smith Nov 23, 2013
    Ok sorry it took me so long to get back to you. Press Windows+R on your keyboard (The Windows key is between ctrl and alt.) It should bring up a dialogue box that says "Run." Type "%appdata%\utorrent" (without the quotions around it.) Press OK and it should bring up a folder. Delete EVERYTHING in this folder. Reinstall uTorrent and try again. Let me know what you find if this doesn't fix it I have other ideas!
    Lynette McCullough Nov 23, 2013
    following your instructions now Aaron. will let you know how it goes. Again, many thanks for your kind assistance. lYN
    the folder read "this folder is empty". nothing to delete.???
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Do you know how to log in to your router and adjust the settings? Most likely it IS a port forwarding issue. Most routers have a way to set up one device in a way that frees up all ports for forwarding. If you know how to do this let me know so I can try and get detailed instructions.
Posted on Nov 21, 2013
  • 1 more comment
  • Aaron Smith
    I would be happy to guide you. I'll warn you routers are tricky little buggers, but we should be able to get this figured out.
  • Aaron Smith
    OK, bear with me I am at work so it may be a while between my replies. First thing I need you to do is to uninstall utorrent. Do you know how to do that? If not I will get you instructions
  • Aaron Smith
    Ok sorry it took me so long to get back. Press the Win+R on your keyboard (the Win is the key between ctrl and alt with the Windows logo on it)
Hi, I'm having problems port forwarding my Thompson TG585 v8. Im trying to port forward for utorrent application but it does not seem to work, everytime i get an error saying "port is not...
- Please check if it's UDP or TCP. You might have selected TCP for port forwarding but Torrent also uses UDP. For some ports that's important to make both forwarding. One for TCP, the other for UDP.
- If this doesn't work, you need to go deeper. You need to have access to an external computer on internet (a friend) from which you can start a telnet. For instance :
telnet mypublicip 45682
On your side, you need to check what's coming on your network interface. Two options to achieve this :
- Either you book a linux live cd (kubuntu), and you run in a console :
sudo tcpdump -ni eth0
(eth0 is the first ethernet adapter of your workstation).
- Either you use wireshark on Windows, this should do the trick, but you cannot be sure that there is no other software blocking on your current installation.
Regards,
Jul 10, 2011 | Computers & Internet
How do I change the NAT setting to open?
Hello and welcome to FixYa.
My guess is that you are looking for port forwarding (eg: port 80 to host a webserver, or maybe a utorrent port for torrent downloads).
These are my suggestions for this issue in general (Assuming you first logged in to your router administration panel. Usually located @ address 192.168.0.1 or 192.168.1.1 or 192.168.0.254 depending on manufacturer can be located underneath the router on a sticker, along with the default admin console password and username):
1. Please enable UPnP to set NAT to open.
2. Goto the port forwarding section (might also be called Virtual server section etc.) and do a port forward using the IP of the computer you need to open port to, with TCP port 80 or 8080 or utorrent port or the number of the port you may need in general.
Please tell me how much did that help you.
More info on this matter that might be helpful can be found==> here
Thanks.
**!Dont Forget to rate how helpful was this solution for you!**
Mar 24, 2011 | Computers & Internet
I need to open a port to use utorrent
first u download a software called ultra surf from anywhere on the net...then this software will search for most suitable port and it will open it for u...
OR
simply u can change the port no. between ' 6880-6889 ' in the preference option in utorrent....I think this will solve ur prob...KSHITIJ
Jun 17, 2009 | D-Link GamerLounge DGL-4300 Router...
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Port forwarding
http://portforward.com/guides.htm
http://portforward.com/english/routers/port_forwarding/Dlink/DI-624/Utorrent.htm
Dec 16, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Utorrent port not working
It doesn't need to be port forwarded unless it is not downloading. But if you must, check portforward.com for instructions specific to your router.
Aug 14, 2008 | Enterasys Distributed Forwarding Engine...
Problem downloading a torrent file
which torrent software is it?
try with utorrent its great and it works good
Jun 14, 2008 | Microsoft Windows Vista Ultimate Edition
Firewall/ports
Hello there, you only need to open a port for utorrent, if you use a Router device for sharing your internet connection to more than 1 computer. If you do indeed own a router then you will need to log-in to it, via your web browser and change the necessary settings to forward the port that utorrent uses, to your local computers address.
Please write again if you need more support.
Hope this helps.
Apr 06, 2008 | Symantec (10427438) Firewall
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
Computers & Internet Logo
101 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
