Question about ASUS Eee Pad Slate Ep121 64gb Wi-fi 12.1" Screen "back Light Problem"
Asus Ep121 backlight fix
Back light will not turn on.
Just installed a motion activated light (model 021746). The light will not turn off; there is no switch.
in the installation notes , it probably reads to this effect
to run the light all the time --switch of power supply and switch on
to run a light sensor - turn the power off , back on back off back on
one action changes the internal program to leaving the light on , the other activates the sensor mode
the switch is the light switch that controls power to the unit
Oct 26, 2016 | Home Security
My back lights don't turn on when lights turn on
My first guess would be a blown fuse. Or a bad wire.
Aug 13, 2013 | Cars & Trucks
Are the back up lights also the license plate lights?
No, they are different. License lights are turned on by the headlight switch. The back up lights are turned on when transaxle is placed in reverse gear. There is a switch on the transaxle that turns the back up lights on.
Jul 19, 2013 | 1997 Oldsmobile Cutlass Supreme
What is the tiny black button on the back of my black berry storm for? Its behind the back cover.
New Power / Lock button usage
Using the Power or Lock button on the top of the BlackBerry smartphone, you can perform the following tasks depending on the state of the BlackBerry smartphone:
State of the BlackBerry smartphone: Unlocked and the back light is turned on
Action: Press and release button.
Result: Locks the BlackBerry smartphone and turns off the back light.
Action: Press and hold button.
Result: Turns off the BlackBerry smartphone.
State of the BlackBerry smartphone: Unlocked and the back light is turned off
Result: Turns on the back light.
Result: Turns on the back light and displays the power off prompt.
State of the BlackBerry smartphone: Locked and the back light is turned off
Result: Turns on the back light and displays the unlock prompt.
Result: Turns on the back light and presents the power off prompt.
State of the BlackBerry smartphone: Locked and back light is turned on
Result: Presents the unlock prompt.
Action: Press and hold.
Result: Presents the power off prompt.
Oct 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
When i turn my headlights on, the back lights turn off.
probably a ground fault , check electrical light system
Jul 13, 2009 | 2000 Jeep Grand Cherokee
My back light does not turn on automatically at night
Most likely a wiring issue. Possibly a wire touching bare metal.
May 21, 2009 | 2000 Toyota Camry Solara
Back light will not come back on.
if your on the back light settings, then press the down arrow three times. if your not, you can tilt it in a certain way so that you can kinda see what your doing
Feb 17, 2008 | Motorola Mobility TracFone® V170 Cellular...
ASUS Eee Pad Slate Ep121 64gb Wi-fi 12.1" Screen "back Light Problem" Logo
167 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
