Question about Ovens
I have a frigidaire electric oven and when I was
I have a frigidaire electric oven and when I was trying to fix the storage door one part of the door detached. How do it fix this
  • 159 Answers
SOURCE: Frigidaire Electric oven model # GLEB27S7C
If you unplug the range and remove the lower rear cover on your left side you should see the motor with 2 switch's on it. There are 3 possibilitys with it. One of the switch's on the assembly is not working or the light switch for the door is not good. You also can disconect the lead to the motor and connect a power cord to it and that will unlock the door so you can check the dor switch also. if you do not feel comfortable powering up the lock motor then you should call a repair man. But one of the switches is not letting the computer know the dor is locked.
Posted on Jul 25, 2007
SOURCE: frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Posted on Feb 23, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Posted on Apr 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
fixyourboard
  • 310 Answers
SOURCE: frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Posted on Jul 25, 2009
How do I Unlock the Frigidaire speed bake oven door
Hi Friend, thank you for your question!
I understand you would like to know how to unlock the door of your Frigidaire oven. May I please have your model number? You can typically locate the serial tag (which lists your model number) inside the storage drawer, on the right side. With this information I can provide you the correct instructions. Thank you! - Z
Jun 05, 2014 | Frigidaire Ovens
How do you unlock my frigdair oven door
Good Afternoon Anonymous, this is Z. I am happy to assist you!
I understand the oven door of your Frigidaire range is locked. May I please have your model number? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can help you unlock the door.
In the meantime, try pressing the CLEAR/OFF or CANCEL button in for approximately three seconds if your range is a touchpad model.
If you have a knob type range control, I suggest starting a self-clean cycle. Then turn the stop time knob to the off position. If that does not work, then disconnect power to your range and reset it by either unplugging it or flipping the breaker off. I suggest waiting roughly ten minutes and then turn on your range.
Hope to hear from you soon and best of luck!
Apr 26, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
How do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Mar 04, 2010 | Frigidaire GLEB30T8A Electric Double Oven
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
Apr 16, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven door falling down on the Frigidaire stove
Try to replace the hinges the locking mechanism is going out
Feb 08, 2009 | Stoves 720EF Electric Double Oven
Oven door won't open on frigidaire electric range ES200/300
Turn the power off at the breaker box for five minutes.
this will reset the system of any electronic glitches.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 01, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
Dec 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Jul 24, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Ovens Logo
12 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
