Question about Toyota Vehicle Parts & Accessories
Air not blowing out dash vents
My air is not blowing out in my Toyota yaris
    Problem Solver:
  • 15 Answers
If u can here your blower motor come on you have a vacuum problem if u can not here blower motor run u got a blown fuse or bad blower motor
Posted on Nov 21, 2013
My 2008 toyota yaris only blows cold air out of one side what can it be?
could be the door in the heater box not working or a hose came off.
Apr 18, 2017 | 2008 Toyota Yaris Sedan
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
Yaris windscreen washers low pressure
Does the fan blow at different speeds? If not, it could be the resistor for the blower that needs replacing. Otherwise it may be a dead mouse, a stuck pencil dropped down the vent, or other restriction.
Aug 30, 2014 | 2004 Toyota Yaris 1.0
2007 Toyota Yaris Sedan check engine light error code P2420
rule 1, P2 means private Toyota code DCT.
where did you see this. on the dash, at autozoned. or where?
where, counts.
2420 means EVAP failure.
bar stool, the gas tank vents are SNAFU'd or FUBAR.
they leak. that is the purpose of evap is to stop fuel fumes from leaking to our fresh air.
and runs test full time. to make that happen.
if it fails the car will not explode or do something dangerous.
i never use forums to find truth here, as most are full of rumor and bull.
i use real Toyota data (the FSM)
data;
Vent valve stuck open (vent)
Following condition met during key-off EVAP monitor:
  • EVAP pressure change when vent valve closed (ON) less than 0.3 kPa-g (2.25 mmHg-g)
that is metric, pressure, convert as you see fit.
  • Canister pump module (Reference orifice, leak detection pump, vent valve)
  • Connector/wire harness (Canister pump module - ECM)
  • ECM
While ignition switch OFF
the PCM toggles the vent valve. and expects a .3kPa change.
id say tighten the gas cap, and reset the eCU, with any scan tool.
see if it comes back, costs zero, effort 5min.
then if it comes back check cap for damage or replace it.
if that dont fix it you will need to test the system.
the FSM covers all that. doing leak down tests, etc.
do you want to do that?
yes, then log in to alldata.com and read.
Feb 11, 2014 | Toyota Yaris Cars & Trucks
A/C blows from defrost and floor vents, nothing from dash vents.
the switch where you turn it to blowing at your head is probably out. you will need to replace the switch control where your defrost, foot, head etc. what make, model, year is your vehicle?
Jul 09, 2009 | 1994 Toyota Camry
I feel like hot air coming from underneath the dash board
Why are you asking this here? Surely you have warranty on a 2008. Take it to the dealer and make your concerns known.
Mar 06, 2009 | 2008 Toyota Yaris
Fan noise when A/C is turned on 2007 Yaris Sedan
You may have some type of debris iside the fan blades on the car. Does the noise sound like a vibrating/drumming/whirring noise? If so, pull the fan motor out & look for debris. Common problem.
Sep 04, 2008 | 2007 Toyota Yaris
Vehicle Parts & Accessories Logo
223 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
