SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
SOURCE: my samsung split system a/c keeps shutting down,
I have a MH050FX A2 that is two head unit and they run only one at a time, when I turn both on, one will shut down. I get an error code of E2 01 with a, I beleive correction code of U C8. Can you help me with a diagnosis??
Kelly Sheehan
SOURCE: Blinking Nature Indicator Light
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
SOURCE: I have a samsung air
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
SOURCE: Hi I a have Samsung
Hi clawrence001,
I believe the main fan may be overheating. I'd inspect it first. Normally these fans can be hooked up to Amp meters, if the Amp reading is higher than the specified ranges on the motor, then the motor is faulty. Be sure to also thoroughly clean the unit when opening it. Poor ventilation can lead to overheating.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please accept it
