Question about Western Digital WD15EADS 1.5 TB SATA Hard Drive
HAD 300 GAMES ON HARD DRIVE AND KIDS DROPPED IT CAN IT BE RESET OR RETRIEVED
    Problem Solver:
  • 17 Answers
As long as the platters inside are not shattered to million pieces, there is always a chance to recover the data but more complex and the amount of data needed, the more $$ it will cost you! There are companies and services you can use for data recovery but as mentioned, this is very expensive and typically used as a last resort for irreplaceable data when all other methods failed.
Now, even if there was a working operating system (Windows or Linux) installed on this hard drive, it is always better to use this drive connected as a slave drive or connected via firewire/USB docking station. That way, even if the operating system was damaged, as long as the data was not encrypted or the sectors where the data resides on were not damaged, you would still be able to access all data and copy it over to another healthy drive/disk.
I am not sure if this is a IDE or SATA type hard drive but there are USB adapters with applicable power connectors to connect pretty much any drive externally to a working system and access it. I use a USB 3.0 based docking station as well as a USB 2.0 based drive adapter which connects to both IDE and SATA 2.5" (laptop) and 3.5" (desktop) type drives and cost around $15.
If any of these are too much for you to grasp or do, take it to a computer shop and have them take a look (typically for free) so, if it was indeed a dead drive, you won't have to second guess it or spend more money on it.
Posted on Nov 21, 2013
How can I retrieve data on a dropped/malfunctioned seagate portable expansion drive?
Not a DIY task. You need a professional with data recovery skills. There are few good ones around.
Jul 07, 2014 | Seagate Expansion 1.5 TB USB 2.0 Portable...
Acer aspire 5735z
The games will slow the system down considerabily, which is a good start. I recommend going to www.download.com Type ccleaner and install, gets rid of a lot of junk on the hard drive, one of the best and it is free, then defrag the hard drive for better performance.
Jul 01, 2012 | Acer Aspire 5500 5570-2609 Laptop
My verbatim 1tb has stopped working after a book dropped on it; it makes repeated cluttering sound when plugged into my computer. Can it be repaired, or at least, can I have the data on it retrieved?
It would be difficult and might not even retrieve the data. The method professionals use is to remove the platters and install then in another drive (expensive).
Apr 30, 2011 | Verbatim 1TB PowerBay Replacement - 96953...
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My 250GB HD250HJ SATA has stopped booting with my other 160gb seagate,i have xp sp3 with amd 4600+,while booting eindows diskcheck starts and finishes after about 1 hour,onnce done it just stays that...
It sounds like your hard drive is messed up. Don't worry you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 31, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hard drive dropped, now not working
The beeping/clicking sound usually means your hard drive isnt far from "death."
You should be backing up all your data and yes, you can find people who get info back from hard drives, but this is very expensive.
Apr 29, 2009 | Maxtor Hard Drive
Help!Help with external hard drive?
Your disk drive is a delicate instrument, it will react negatively if dropped on the floor.
However what you might try all be it rather radical in this age of micro fine technology is. take a deep breath and sit down. Take the disk drive in your left hand with the edge of the drive that struck the floor facing away, make a fist with your right hand and strike the opposite edge with with almost equal force.
The reason behind this is simply that when you dropped your drive on the floor the heads got jammed either into the disk spool or out side of it,
If you have to pay $300 for disk recovery you cannot be doing much worse than trying this before you have to.
Oct 20, 2008 | Maxtor OneTouch II external hard drive...
External hard drive
It sounds like your hard drive is damaged my friend. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especiaiy dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
May 15, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
I dropped it on a floor. Now it gives an alarm sound.
wow..you'll need to get a data recovery expert to 'snapshot' your drive to attempt to recover your data. I'd suggest that the 'drop' did a major mechanical deal, like a head impact crash. Not good. A local tech store/computer shop MIGHT have the tools to extract the data. Last time I checked, it runs from 100 to 300 bucks, depending on what kind of files are retrieved.
Feb 16, 2008 | LaCie BRICK (301063U) 300 GB Hard Drive
Western Digital WD15EADS 1.5 TB SATA Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
