Question about Remington Garden
Removing the bolt on sportsman 78
Removing the bolt
I. Need. Help. With. Cam bolts. And head bolts
Part 1 of 3: Getting to the head bolts
Materials Needed
  • Eye protection
  • Gloves
  • Oil and coolant drain
  • Parts cleaner or brake cleaner
  • Shop rags
  • Socket set and ratchet1: Drain the oil and coolant. Put on your eye protection and gloves and drain the oilfrom the vehicle.
    Make sure the vehicle can not be started by removing the negative cable from the battery. Next the coolant will need to be drained so it does not leak when the head bolts are loosened.
    Step 2: Clean valve cover. Use some of the parts cleaner or brake cleaner to clean up the valve cover and as much of the cylinder head as is reasonable.Remove valve cover. If necessary, remove other components to make the valve covers accessible, and start removing the bolts from the valve cover.
    Once all bolts are removed carefully removed the valve cover from the cylinder head. If any valve cover gasket material remains, remove it at this time and clean any excess oil from the edges. Set the valve cover aside carefully as it will be reused with a new gasket once repairs are completed.
    Part 2 of 3: Pushrod engine head bolt removal
    Materials Needed
    • Head bolt socket (if needed)
    • Numbered cardboard
    • Rubber hammer
    • Socket set and ratchetStep 1: Rocker arm and rocker removal. A pushrod engine has long pushrods that protrude through the cylinder head and attach to the rocker rail.
      The rocket arm will need to be loosened first. Many manufactures have a specific sequence for removal of the rocker arm bolts. After the rocker arm is removed, the rockers will be unbolted.
      Set all rocker arms aside in the order they were removed as they should go back to the cylinder they were removed from.Step 2: Remove the pushrods. Remove the pushrods one at a time from the cylinder head.
      Put them into a numbered piece of cardboard as the pushrods will go back into the same slot they came from.Step 3: Loosen head bolts. Use the ratchet begin to break the cylinder head bolts loose.
      Each bolt will be loosened but not removed. Loosen all of the bolts before removing any of the the bolts all the way.
      Step 4: Remove the bolts. Place each bolt through a numbered hole in the cardboard in case the head bolts are different lengths so they can be installed back into the proper hole.
      The bolts may require a special socket depending on the manufacture.
      Step 5: Lift off the cylinder head. Once all bolts are removed, lift up on the cylinder headgently; the head should come free easilyIf the cylinder head sticks, lightly use a dead blow or rubber mallet to tap the cylinder head to be able to remove it. Set to the side in a safe area.
      • Warning: Cylinder head bolts have a specific sequence that is used when removing them. Consult the manufacturer's specifications for the proper removal sequence for the engine being worked on.
      Part 3 of 3: Overhead cam head bolt removal
      Material Needed
      • Socket set and ratchetStep 1: Remove the timing cover. The timing cover will need to be removed to gain access to the timing belt or chain.
        This is necessary because the cam shaft sits in the cylinder head and is attached to the crankshaft with either a timing belt or timing chain.
        Step 2: Time the engine to remove the belt. The engine will need to be timed to avoid damage when the timing belt is removed.
        Each engine is different and will have its own procedures to time. There should be marks on the camshaft and crankshaft that will be aligned to set the timing at top dead center (TDC)Step 3: Remove the timing belt. The timing belt tensioner will be removed or released to take the tension off the belt.
        Once the belt is loosened, it should be able to be slipped of the camshaft in the cylinder head.Step 4: Remove the head bolts. Every engine will have its own procedures for the order that the head bolts are removed or tightened.
        Loosen head bolts ΒΌ turn each in the order specified, which may require a special socket. Once all the bolts have been loosened they may be removed one at a time. The bolts must be organized or marked in case they are different lengths.
        Step 5: Remove the cylinder head. Once all the bolts are removed, the cylinder head may be removed from the engine. If it is stuck, tap lightly on the side of the head with a rubber hammer to loosen the cylinder head.
        • Warning: Most head bolts are torque-to-yield. These head bolts are single use only and once removed must be replaced. Torque-to-yield head bolts stretch when they are torqued to allow them to tighten properly and repeated application can cause the head bolt to break.
        Removing the head bolts can seem like a daunting process
Sep 29, 2016 | Cars & Trucks
I have a 2013 sportsman Polaris 500. My atv stalled out while riding today and no lights or nothing will come back on. The battery is not dead either. And I checked the fuses?
These machines depend on a good ground. Make sure your ground connections are all clean and tight.... especially the ground wire from the battery to the frame. I recommend removing the battery terminal wires and cleaning the terminals... Also the negative cable that bolts to the frame... remove the bolt and sand the terminal that bolts to the frame. Check for in-line fuses... There is one in-line fuse near the battery!
Oct 03, 2015 | ATVs
How do you remove the rotor on a sportsman gen154 generator?
The bolt in the end where the exposed bearing is a very long bolt.It goes thru the entire length of the generator and threads into the crankshaft of the engine. Loosen this bolt slowly but firmly since it will twist a lot before it breaks the threads loose. Once the bolt is out if the rotor doesn't come off easily, then give it a nudge with a rubber mallet.
Jun 18, 2015 | Electrical Supplies
I have a Remington 223REM sportsman 78 serial # C6240048 that I would like to know the date of manufacture. Thanks Wayne
The barrel was made in 1982 according to the number you have given which is the closest year to the first year that the model 78 was manufactured 1984 but the C prefix could also be for the month of April
So unless you put all the letters preceeding the number string a date would be a guess
Take a look at website
Remington society.com/rsa/questions/barrelcodes on how to read a Remington serial number
Mar 13, 2015 | Optics
How to change alternator 2005 chryler 300
This answer covers:
2005 Chrysler 300 6cyl VIN "G" 3.5L SFI HO (72% of 2005 300's)
2005 Chrysler 300 6cyl VIN "R" 2.7L MFI DOHC (28% of 2005 300's)
2005 Dodge Magnum 5.7L engine
Alternator
Removal & Installation
WARNING - Precautions Section:
Disconnect negative cable from battery before removing battery output wire (b+ wire) from alternator. Failure to do so can result in injury or damage to electrical system.
2.7L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect negative battery cable.
  3. Remove alternator drive belt.
  4. Disconnect alternator field circuit plug.
  5. Remove B+ terminal nut and wire.
  6. Remove 2 lower mounting bolts.
  7. Remove alternator.
To install:
  1. Install alternator.
  2. Install upper bolt mounting bolt.
  3. Install 2 lower mounting bolts.
  4. Tighten bolts to 48 ft. lbs. (65 Nm).
  5. Install B+ terminal nut and wire. Tighten nut to 115 inch lbs. (13 Nm).
  6. Connect alternator field circuit plug.
  7. Install alternator drive belt.
  8. Connect negative battery cable.
3.5L Engines
  4. Remove bracket bolts.
  5. Remove upper mounting bolt.
  6. Raise and support vehicle.
  7. Remove middle splash pan.
  8. Disconnect alternator field circuit plug.
  9. Remove B+ terminal nut and wire.
  10. Remove lower mounting bolts.
  11. Remove alternator.
To install:
  2. Install lower mounting bolts. Loosen install the upper mounting bolt.
  3. Tighten lower mounting bolts to 48 ft. lbs. (65 Nm).
  4. Connect alternator field circuit plug.
  6. Install middle splash pan.
  7. Lower vehicle.
  8. Remove loose installed upper bolt.
  9. Install bracket and bracket bolt.
  10. Install upper mounting bolt and bracket.
  11. Tighten upper mounting bolt to 48 ft. lbs. (65 Nm).
  12. Tighten the bracket bolt to 40 ft. lbs. (54 Nm).
  13. Install alternator drive belt.
  14. Connect negative battery cable.
5.7L Engines
  2. Disconnect negative battery cable at battery.
  4. Raise and support vehicle.
  5. Unsnap plastic insulator cap from B+ output terminal.
  6. Remove B+ terminal mounting nut at rear of alternator. Disconnect terminal from alternator.
  7. Disconnect field wire connector at rear of alternator by pushing on connector tab.
  8. Remove alternator support bracket nut and bolt. Remove support bracket. See Figure 1.
  9. Remove 2 alternator mounting bolts. See Figure 2.
  10. Remove alternator from vehicle.
Fig. 1 Alternator Support Bracket - 5.7L engine
Fig. 2 Alternator Mounting Bolts - 5.7L engine
Oct 13, 2014 | 2005 Chrysler 300
How to remove oil pan
4x4
1. Open the hood.
2. Disconnect the battery negative cables.
3. Remove the intake air assembly.
4. Remove the radiator shroud retaining bolts.
5. Install engine support fixture # 8534B .
6. Raise and support the vehicle.
WARNING: HOT OIL CAN CAUSE PERSONAL INJURY.
7. Drain the engine oil (Refer to 09 - Engine/Lubrication/OIL - Standard Procedure) .
8. Loosen the front engine mount bolts.
9. Lower the vehicle.
10. Use the engine support fixture # 8534B to raise engine out of the front mounts.
11. Remove the engine oil dipstick.
12. Raise and support the vehicle.
13. Remove oil pan bolts, break the pan to block seal, and lower pan slightly and remove oil suction tube fasteners.
14. Remove oil pan and suction tube.
15. Remove the 2 bolts from the front of the engine block stiffener.
16. Remove the oil pan.
4x2
1. Open the hood.
2. Remove the negative battery cables.
3. Raise and support the vehicle.
4. Remove the transmission oil cooler lines.
5. Remove the propeller shaft.
6. Remove the starter bolts.
7. Support the starter.
8. Remove the torque converter bolts.
9. Remove the exhaust hanger bolts.
10. Remove the gear shift cable.
11. Remove the wiring harness.
12. Remove the transmission mount.
13. Remove the crossover bolts.
14. Position the transmission jack.
15. Remove the bell housing bolts.
16. Remove the transmission.
17. Remove the flywheel housing bolts (8).
18. Remove the flex plate bolts (8).
19. Remove the engine oil dip stick.
20. Drain the oil.
21. Remove the steering rack bolts.
22. Remove the oil pan bolts.
23. Remove the oil pickup bolts.
Aug 01, 2014 | Dodge Ram 3500 Cars & Trucks
How do I remove the handle bars from a 2004 sportsman 700 efi
Look in the middle of the bars there should be 4. Bolts of screws to remove the cover. And you have to take all brake controls and switches off to remove Handel bars
Jul 05, 2014 | ATVs
2009 polaris 850 sportsman, reverse will not work.
put some grease in the tranny, and while your at it check th back diff too, by just loosening the pumpkin bolt and sticking your finger in there to see if there is enough 75/90, if not just ADD TO THE PUMPKIN till it reaches the top of the bolt hole while the unit is sitting on its 4 wheels it should just be spilling out at the threads put bolt back in and hand tighten then snug but not too tight, tht should do it.
Mar 31, 2014 | Polaris 2009 Sportsman 850 EFI XP With EPS
How to remove starter from 2004 pacifica
REMOVAL
Disconnect the negative battery cable.
Remove (UPPER RADIATOR CROSS MEMBER) and relocate (UPPER RADIATOR CROSS MEMBER REMOVED) the upper radiator crossmember, (Refer to 23 - BODY/EXTERIOR/RADIATOR CROSSMEMBER - REMOVAL).
Remove the radiator fan module (FAN MODULE IN VEHICLE) (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
Remove the wiring harness clip from front mount.
Remove the coolant line clamp bolt (COOLANT LINE BRACKET).
Remove the upper nut from the front mount (FRONT RUBBER MOUNT UPPER NUT).
Remove the upper starter mounting bolt (UPPER STARTER BOLT).
Remove the middle starter bolt (MIDDLE STARTER BOLT).
Raise vehicle and support.
Remove the lower front mount nut (FRONT RUBBER MOUNT IN POSITION).
Raise and support engine (SUPPORT ENGINE).
Remove the lower bracket bolt to transmission (BRACKET TRANS BOLT).
Remove the lower bracket bolt to engine block (BRACKET ENGINE BLOCK BOLT).
Relocate the front mount and bracket.
Disconnect the positive battery cable from starter
Disconnect the solenoid connector from starter.
Remove the lower starter bolt (STARTER LOWER BOLT).
Remove starter from vehicle.
Aug 16, 2011 | 2004 Chrysler Pacifica
I broke the crankshaft bolt what do i do?
ok witch bolt is it. On most tuff bolts that I break trying to remove or install I use a left hand drill bit and then if that does not catch and remove I use an easy out but let it soak for a while with some WD-40 first
Dec 17, 2010 | Chevrolet Impala Cars & Trucks
Garden Logo
29 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
