Question about Sony CFD-S350 Radio/Cassette/CD Boombox
Replace speakers]want to replace speakers - Sony CFD-S350 Radio/Cassette/CD Boombox
Telefunken TLC037fhda no sound picture good
take a look at the speaker,use a multimeter see if the speaker have the rated resistance.( eg .8 ohms) if speaker bad replace if.if speaker good. see if your audio amp is getting power (multimeter needed) set to d.c volts.have voltage then look for the input pin that brings audio into the amp,use a 16 -32 ohms speaker across gnd pin and input pin(bring volume up hi on tv) if audio replace audio amp.
(also look for cold solder) on p.c board before replacing amp.
May 23, 2014 | Televison & Video
My Roland Street cube amplifier has a bad speaker- where can I find a replacement speaker?
Rubber cement is an excellent for minor speaker cone damage but if you feel that a replacement is required, try MCM Electronics online. They carry lots-o-speaker replacements. Be sure to match wattage and impedance (ohms) of the speaker though as these are important spec's.
May 21, 2014 | Roland Cube-st Battery Powered Amp Cube...
CS-2724R speakers starting to sound distorted. Can speakers be replaced @ home or must be done by qualified tech? Will replacing speakers likely fix problem or could the diminishing audio quality be a...
Replacing speakers are not a skilled work, can be done at homw. But, reason for distortion should be troubeshooted before replacing the speakers, and make sure that the distrotion is due to damaged speakers itself. Otherwise it will be a waste of money. It will be best to contact any service technician.
Aug 25, 2013 | Mitsubishi CS-13103 TV
Need replacement speaker for clarion psw160
I had the same issue. The edge of the speaker deteriorated. I sent the speaker to Orange County Speaker in Garden Grove, Ca. They will repair/re-test/and certify the speaker for $45.00. There is no direct replacement due to the bolt pattern and screw hole in the magnet.
May 11, 2013 | Clarion PSW160 Car Speaker
Need a replacement speaker. I am looking for the flat speaker the non powered speaker.
You can contact them at: products@benwin.com to ask them about getting a replacement. If they don't offer a replacement you might have to buy a new speaker system.
Dec 17, 2009 | Benwin GX-6A Computer Speakers
Replaced rear factory speakers now have low volume
Factory speakers usually have low resistance ( 2 ohm) When replacing speakers with aftermarket, most aftermarket speakers will be 4 ohm. If you want the same sound you may have to buy some resistors to put on the speakers (across the + and -). By putting a 4 ohm resistor across the connectors will now make the speaker 2 ohms which in effect will raise the volume. Depending in what vehicle you replaced the speakers the resistance will vary.
May 18, 2009 | Sony CDX-GT500 CD Player
How do i replace a broken speaker in passport 9500i
The speaker is manufactured by PUI, but it is a custom OEM job for Escort. So you can't get it from any distributor or from PUI. In the late summer of 2007 Escort started installing a new "high temp" speaker. This new speaker looks just like the original speaker, but it is designed to be able to handle very high temperatures without blowing. If your 9500i is still in warranty, Escort will replace the speaker with the new "high temp" speaker, test and calibrate your 9500i, and install whatever their latest firmware is. If your 9500i is out-of-warranty, then you should call them and see if they will send you a replacement "high temp" speaker for a small charge. The speaker is easy to replace. A good while back I posted on radardetector.net detailed instructions on how to replace a 9500i speaker. It takes all of 10 minutes to do.
Mar 05, 2009 | Passport 9500i Radar/Laser Detector
Can you get sound if you are missing the central speaker?
Self powered speakers are configured to get their voltage from a source outside the PC, so you'll need to replace the central unit that provides the power or replace the speaker system. As for a replacement you can Google the Brand Name and model of the speaker and you may find a source for a replacement that way.
Good luck.
Feb 12, 2009 | Dell 5650 Computer Speakers
I guess its the speaker that is not working
johanita - have the phone speaker replaced.
oleg83 - ear piece speaker needs to be replaced
heyari - replaced the speaker
GUEST - replaced the speaker on the phone
tina-ehmm-72 - the ringer and ear piece needs to be replaced
hashah - replaced the speaker
May 29, 2008 | Sony Ericsson W850i Cellular Phone
Sony CFD-S350 Radio/Cassette/CD Boombox Logo
27 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
