Question about McCulloch Garden
Fuel line is leaking gas on a McCulloch Super Airstream IV gas blower
The fuel line is leaking on my McCulloch Super Airstream IV Gas Blower. Is this something that I can replace myself?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Yes it may take some disassembly to get there, but yes.
Posted on Nov 23, 2013
  • 33 Answers
SOURCE: fuel lines may be crossed, appears as though air is getting into carburetor.
you do have the lines wrong
Posted on Jul 13, 2009
trippssmengi
  • 76 Answers
SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Posted on Jan 06, 2009
  • 398 Answers
SOURCE: Lenght and position for Ryobi RY08548 Blower fuel line in gastank
take off the fuel filter and see if that works . if it runs then it needs a new fuel filter. keep me posted
Posted on Apr 14, 2009
  • 15 Answers
SOURCE: fuel mixture for 32 CC McCulloch leaf blower
Gas to Oil ratio is 40 to 1. (40:1)
Posted on Jun 07, 2010
rycgl
  • 1545 Answers
SOURCE: My MCCulloch super airstream IV blower has only
Iam going to refer you to the Zama carburetor tune-up and adjusting guide for all this instruction.
http://www.zamacarb.com/tipspage.html
Posted on Dec 10, 2010
Broke small black connector between fuel line to side of carburetor. Flat bottomed funnel shape fits in to side of carb. Has filter inside. I believe it feeds the primer.
That is a fuel tank vent kit. Most models have a vent in the fuel cap but that model uses a separate line with a Duck bill vent (usually a green rubber inside that piece in picture). Part number for that is 574859301 . Your blower should run ok with out it but could leak fuel. If you are going to order any parts for your blower do so using Model # PPBP30 Your parts will be cheaper. That particular model has exchanged hands between MTD/Mcculloch/Bolens and Husqvarna/Poulan over the years. The parts are cheaper when you use the Husqvarna/Poulan model # PPBP30. Only noticeable difference will be a yellow starter housing if you buy a starter assembly.
Dec 17, 2015 | McCulloch ASB3206 - Blowers - 30cc Gas...
Why does my backpack blower suck all the gas into the cyl. when it sits
I'm trying to understand the question, very strange. The only way this is possible is that the carburetor meter valve is causing the fuel needle to remain open, but then you should see fuel coming out of the carburetor , leaking from there... basically the fuel needle isn't closing allowing continual fuel to proceed
Oct 11, 2015 | McCulloch 26cc Gas Backpack Blower Dual...
Gas leaks out during use.
Mine is doing the same thing, I need to replace the gas cap on it. The other thing that you need to check is the fuel lines, the ethanol eats everything up.
Oct 25, 2010 | McCulloch 26cc Gas Blower Mcb3208
Craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
May 26, 2010 | Poulan Featherlite Gas Blower, with Low...
Mccolluch airstream V back pack blower fuel lines
The short one goes to the primer bulb and the long one, with the filter, goes to the carb.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Fuel mixture for 32 CC McCulloch leaf blower
Oct 12, 2008 | Garden
Garden Logo
309 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
