Question about Kitchen Appliances - Others
Foodsaver v550 the sealer strip is not working I put the plastic on the strip close it and press on it sounds as if its working but it do not shut off nor doe's the light come on
4 Suggested Answers
  • 88 Answers
SOURCE: My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Posted on Aug 22, 2009
  • 88 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
Foodsaver repair
Sorry to laugh, but that is too funny!
These retractable cords are very difficult to get back in order. You would be better off just closing up the sealer and allow the cord to remain extended. You could spend hours rewinding the cord and setting the tension spring when it pops open and makes you a crazy person.
Mar 12, 2014 | Kitchen Appliances - Others
V3840 heat strip doesn't get hot
Could be the heating element (wire that gets hot enough to melt plastic) is going bad, how long have you been sealing bags with the unit? If you have used it for some time there is the possibility of build up plastic/residue on the the wire or the surface that actually comes in contact with the bag as I would suspect there is a coated surface the element heats up as opposed to the element / wire coming in contact with the plastic itself!
Nov 19, 2017 | FoodSaver Vacuum Food Sealer - V3840
Foodsaver troubleshooting
The same thing happened to mine and I found a really,really inexpensive way to resolve it. I don't use original foodsaver bags and I found out that their thickness might not be detected correctly so it won't vacuum. To compensate for this, I used an ordinary piece of notebook paper. I cut it to a size of 4 1/2" by 1 1/2". I set the long side in the middle of the liquid catching tray and let it lean back towards the heat strip. Make sure it doesn't cover the heat strip or it won't seal. Now I inserted the bag as the directions say, close and lock the top, and it vacuums and seals perfectly. b40a3e78-1fd3-4c38-9291-c5c4e3885648.jpg
Jan 05, 2014 | Kitchen Appliances - Others
Need to replace the heat stripe tape on my tilla foodsaver vaccum sealer
concerning my food sealer: the strip under the heating wire came loose & would not stay in place. i almost threw the unit away but its at least $40 to buy another. i decided to buy a roll of PTFE Coated Fiberglass Fabric With Silicone Adhesive Tape. PTFE is Teflon but u cant use Teflon as a search term because of the copyright. i found a roll on ebay for $3 (free ship) from China (how do they do that!). it took about 2 weeks for the roll to arrive. I cut a strip to fit under the wire. The wire had burned & partially buried itself in the unprotected plastic. Be gentle when nudging it out & clean off any material that has attached itself to the wire. Seals & works like new!
would you like to buy the rest of the roll? the roll has about 28 feet left.
Dec 27, 2012 | Kitchen Appliances - Others
Vacum works heatseal does not seal can i replace seal
Sealing always tends to be the problem with FoodSaver because during the course of normal wear and tear, the sealing strip and wire will naturally need to be replaced.
You can get replacement heating wires and strips at www.elementandteflon.com
We started out selling just replacement parts for heat impulse sealers but we kept on getting customer requests for FoodSaver parts so we've added that section to our website.
Dec 14, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver vac800 not sealing bags any way to fix heat strip?
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Sep 16, 2010 | Tilia Foodsaver V835 Vacuum Sealer
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
How do I turn on my tillia foodsaver my friend lent to me?
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Sep 28, 2009 | Tilia FoodSaver V2240
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
