Question about Casio Gz One Commando Android Smartphone
How to you free up RAM on medion E4002
My phone has low RAM memory
Low memory message
Unfortunately, on many cell phones that don't have very much main memory, the standard set of apps on an android phone will tend to take up the majority of the free memory. This leaves you with next to no main memory to install apps in. You'll find that many phones that have 8gb of ram suffer from this issue when they've hardly installed any apps at all. You can try installing a micro sd card to expand the memory and see if your phone will allow you to move any of the applications to the memory card to free up space in the main memory. Having to deal with this is very frustrating and, the only real solution I know of is to try to make sure that any phone you upgrade to has no less than 16gb ram, hopefully 32gb minimum and having an expansion memory chip (MicroSD card) that you can save any pictures, music & other files to ..with hopefully the ability to move some apps to the MicroSD memory as well to keep from running into the same Low Memory problem again.
Best of luck. I hope this helps some..
Sep 25, 2017 | Cell Phones
Memory problems
How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
Mar 08, 2013 | Dell VOSTRO 3350
Phone keeps showing "C Phone memory full delete
phone memory should always be free... its the ram for your phone... you shoul keep all your files , applications and messages in memorycard ..... if memory in phone is low it will work slowly and you will not be able to open large sized applications in your phone
Oct 11, 2011 | Nokia N73 Cellular Phone
I am having nokia 3110c mobile when i am sending a song to mobile it says that operation failed due to low phone memory how can i made it directly into memory card instead of phone memory
It means that the ram of your phone is low or your phone memory is low move some items from phone to mmc if still does not work do a format by following code *#7370#
Mar 27, 2011 | Nokia 3110 Cellular Phone
N-73
your phone memory is too low remove some data so your cell's ram memory will work right
May 26, 2010 | Nokia N73 Cellular Phone
Storage memory low msg
the messages will be stored in ypur phone memory .. and you will be deleting the files from memory card.. make sure that you delete the files from phone memory... then u can receive messages
Apr 07, 2010 | HTC Touch Diamond Smartphone
Not Enough Heap? E-mail won't launch. Gives that message .
this is because your phone runs low on heap memory or ram memory, try upgrading your phones software.
Or format it by entering this code *#7370# on main screen.
please note all ur phone memory data while formatting.
Apr 01, 2010 | Nokia E71 Smartphone
Bluetooth problem
it might be that the phone on which you  are sending data is low on phone memory. If not your phone is low in phone memory. phone uses the phone memory  as its RAM if it is not free that it will not be able send data. pls vote me.
Feb 13, 2009 | Sony Ericsson Z550i Cellular Phone
RAM of my nokia 6681 is too low
Offcourse you can increase RAM of your Nokia 6681 Mobile..
Go to nearby Mobile Shop and purchase a Memory Card of expandable memory..
Thanks
Fix it Out
Feb 02, 2009 | Nokia 6681 Cellular Phone
Casio Gz One Commando Android Smartphone Logo
171 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
