Question about Whirlpool LCR5232H Top Load Washer
Hi i cant open my washing machine even its already finished washing lights on the progam keeps on blinking please helps me thanks
Its new what will i do
  • 3 Answers
IF ITS NEW CALL THE MANUFACTURER OR THE STORE YOU BOUGHT IT FROM IT SHOULD BE UNDER WARRANTY. SOUNDS LIKE YOUR DOOR LOCK IS STUCK IN LOCK MODE. COULD BE BOARD OR LOCK
Posted on Nov 22, 2013
jsrock516
  • 5911 Answers
SOURCE: washing machine blinking f-24 error code.
"F24" is a Water Temperature Sensor error or Heating Circuit failure. The first step to troubleshooting these washers is to unplug the unit for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes the error codes can be erroneous and a simple reset of the CCU will correct the problem. If the error code reappears following a CCU reset, you have a genuine problem.
If the error code comes back, check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Check to make sure the connector is still plugged in. The connector can become loose or unplugged due to vibration. If the connector appears to be okay, unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope you find this information helpful. If you have further questions, please let me know.
Posted on Apr 12, 2009
  • 73 Answers
SOURCE: washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 23, 2009
  • 299 Answers
SOURCE: Washing machine isnt' draining nor spinning.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Posted on May 02, 2010
  • 1382 Answers
SOURCE: F1 in time remaining window
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Posted on Jul 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: cabrio washing machine wont finish
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
F&P MW512 TopLoader washing Machine has no power
I would be having the capacitor for the motor checked as they do fry and not work
Jun 27, 2013 | Fisher and Paykel Washing Machines
When washer starts it usually makes a clicking noise know it is humming and nothing happens the door is locked and wont open
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Aug 23, 2010 | General Electric WCVH6800J Front Load...
My zanussi washing machine fj1033 finishes normal wash progam but doesnt go into hihg spin therefore clothes are wet rather than damp.if i turn dial to spin cycle only it works that way.please advise.
If you have not already done so, then check and clean the pump filter, this is usually located at the bottom right front of washer, behind a drop down cover or flap.
Unscrew anti-clockwise to remove and clean.
Jan 08, 2010 | Washing Machines
Tvättmaskin stannar mitt i tvättning med felkod C9 och lamporna för "Förtvätt" och "Skjölning" blinkar. Har ni några förslag? The washing machine stopped mid-wash...
Change motor brushes and reset by doing the following
press first 2 buttons 1 & 2 keep it pressed and turn program switch 1 click to the left (against the click)
all LED’s lights up.
realise the buttons
turn progam switch to off
Only do the above after replacing the brushes and still doesnt work
Oct 25, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error messege, front loader wont start.
my name is joyce
first try the simple step, unplug unit for 60 secounds, then replug unit back up. reset load and see if that works. let me know if I can be of further assistance.
joyce
Feb 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine
DOWNLOAD A MANUAL OF THE WEBSITE.SOME DOORS YOU HAVE TO LEAVE FOR A COUPLE OF MINUTES THEN THEY WILL OPEN,IF YOU KEEP SWITCHING OFF AND ON IT WONT WORK .
Aug 08, 2008 | Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool LCR5232H Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
