Question about Polycom VoiceStation 300 Conference Phone
How do I conference call on this phone
I want to know how I can conference in people on this phone.
I dont know how to make a conference call
Activate Call Waiting in Call Settings.. From Then On you will get the 2nd Call on Waiting... U can answer the 2nd Call while holding the 1st Call and Then Make CONFERENCE
Aug 07, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
Panasonic kx t7436 how many conference will do conference
you can do as many conferences as you have phones, but one phone can have one conference at a time with 3 total parties(depending on your phone system) in the conference (so yourself and 2 other people, inside or outside of the office)
if you have a TDA/TDE/NCP phone system (blue box on the wall or in a computer rack) you can have 5 people in a single conference...
if you have a TD phone system (white box on the wall) you are limited to a 3 party conference
Jan 06, 2011 | Panasonic KX-T7436 Phone (KXT7436000000)
When I try to make a conference call from my E63 cell phone...It throws a message saying "Request Rejected"..Please help me with this issue..Let me know if any other setting has to be made to...
all you need is to activate call conference service then you can make conference calls without any issue,call your service provider to activate this service
hope this will help
Nov 16, 2010 | Nokia E63 Cell Phone
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
We have an old polycom sound station which is not wireless and does not have the screen. We need to conference with 2 people. I know we can do it with the soundstation 2w but can we do it with the old...
It would depend on if this is going through the phone system, or just a phone line all by itself.
If on the phone system, there should be a conference button, that is like a "flash" button on your home phone.....
Sep 01, 2010 | Polycom SoundStation
Nokia 1100 Mute Reg
WHEN you are in conference ..
go to options(that is press left soft key)..dont worry the call will be continued..
then,it displays a list of options,press down until you see mute,click mute and the calls will be muted...
Feb 24, 2010 | Nokia 6085 Cellular Phone
How do I conference call on a Polycom Voicestation 400?
Conference call is not a feature of the phone, but a feature of the telephone system in the company. Usually you press a sequence of keys like flash #02 to trigger this function in the phone system. If your company phone system does not offer the feature then you have to use an external conference call provider.
Jun 17, 2009 | Polycom VoiceStation 300 (220017910001)...
Conference Calls/Transfer
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
May 21, 2008 | NorStar Meridian M7310 Phone
Avaya Speakerphone
No, that was a drawback of the 44xx series phones. You should use a Polycom conference phone for a conference phone.
Apr 25, 2008 | Avaya 4412D Corded Phone
Polycom VoiceStation 300 Conference Phone Logo
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
