Question about KitchenAid KUDE70FXSS Builtin Dishwasher
Kude70fxss leaks when started - KitchenAid KUDE70FXSS Builtin Dishwasher
Kitchen aid dishwasher stopped mid-cycle and won't drain. Can't re-start. Suspect clogged drain.
This blog might help: http://www.applianceblog.com/mainforums/threads/24574-Dishwasher-stopped-mid-cycle
Mar 10, 2015 | KitchenAid KUDE70FXSS Builtin Dishwasher
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
Pump clamp failure fixed and now dishwasher clean light blinks 4 times and controls are locked
I would start by calling that Technician back out. If it is a common problem with your model, did the technician inform you of that when he was there last? Did he even mention the POSSIBILITY that the pump might have water in it and may need to be replaced?
If not, I'd want to know why not. This sounds like something he should have been aware of and checked for, especially if he was a Kitchen Aid appliance service technician. That's the way a "handyman" might do something, but not a certified repairman.
Nov 28, 2013 | KitchenAid KUDE70FXSS Builtin Dishwasher
Leaking power steering fluid on cold start up
Metal shrinkes when it's that cold causing this,will have to just do what it takes to keep going.
Dec 30, 2012 | 2001 Ford Escape
Kude70fxss check valve
After the wash the drain valve must be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 11, 2012 | KitchenAid KUDE70FXSS Builtin Dishwasher
Kude70fxss
Do you still have water down the bottom of the unit? Usually when you are hearing that pump noise that is from the drain pump and the reason it is constantly running is usually because there is an obstruction either blocking the hose or blocking the pump from evacuating all the water from the unit. This is a fairly common issue on all dishwashers. Remove the spinner on the inside of your unit and assure that there is nothing blocking the port exit hole. If there is not then you will have to de-install the dishwasher and pull the unit out and remove the drain hose to assure nothing is stuck inside the hose and at its connection point usually to the disposal under your sink. Remember to turn off the water as well as the power before you de-install. If you have any further questions message me back. I await your reply
Thank you,
Rick
Jan 10, 2012 | KitchenAid KUDE70FXSS Builtin Dishwasher
The control lock light is on my KitchenAid dishwasher KUDE70FXSS... I called for help and the hotline told me I need a technician to come out! How can that be? The dishwasher is brand new and I simply...
Hello & Welcome to FixYa
Press and Hold the HEATED DRY/NO HEAT DRY button for 20 seconds to unlock the control. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | KitchenAid Dishwashers
2000 VOLVO S80 HAS A LARGE VACUUM LEAK. HOW DO I
In the past we have used starting fluid to find vacuum leaks. Start the engine, let it idle. Spray quick shots of starting fluid at your vacuum lines in isolated areas. When the starting fluid find the vacuum leak the engine will react to it... usually by going up in rpm. Depending on your engine computer, it may stall the engine. Either way you will find your vacuum leak. Get starting fluid or "ether" at Autozone or O'Reilly.
Dec 01, 2009 | 1999 Volvo S80
Fuel leak
If you see the leak when you start the vehicle then you know where the leak originates from. You need to address the leak and find the solution to stop the leak. The leak does not go away. The extra heat just evaporates the fuel faster than it is leaking. This may make you think it stops when actually it has not.
Mar 12, 2009 | 1985 Ford LTD
Fuel Leak
I wouldn't drive or start it with a fuel leak, it needs to be up on a lift to see it all clear, before any proper diagnosis.
Oct 20, 2008 | 1996 Saturn SC
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
