Question about BellSouth Radio Communications
Model 1010 cant talk through one device
Need house & home dehydrator manual
Hello, Vickie -
Do you know the model of your House & Home Food Dehydrator?
Apparently the House & Home Model LD-1010 Food Dehydrator is the same as the Magic Chef Model LD-1010 Food Dehydrator. Also, I have seen information indicating the model LD-1010 is the same as (or very close to) model 469-1. Perhaps yours is a a model LD-1010
I have not yet found a PDF version (electronic, Adobe Acrobat Reader software) of an instruction manual for a House & Home food dehydrator or a Magic Chef food dehydrator, any model.
However, I have found directions (not the full manual) for using a Magic Chef food dehydrator here:
https://www.leaf.tv/articles/instructions-on-using-a-magic-chef-food-dehydrator/
I have found manuals for other similar food dehydrators (PDF documents), which may prove instructive:
http://pdf.lowes.com/operatingguides/1000317095_oper.pdf
and:
https://www.manualslib.com/manual/107232/Mr-Coffee-Fd5.html
Note: I also found a 1997 U.S. Consumer Product Safety Commission for a K-Tel Model LD-1010 food dehydrator:
https://www.cpsc.gov/Recalls/1997/cpsc-k-tel-international-usa-inc-announce-recall-to-replace-food-dehydrators
I have not been able to determine if the K-Tel product was manufactured by the same company which made the House & Home LD-1010 Food Dehydrator or the Magic Chef Model LD-1010 Food Dehydrator. However, I recommend you read the full recall notice and be watchful for any overheating when you use the dehydrator.
Note: If you eventually choose to dispose of the dehydrator, please do not toss it in the trash. Instead, make sure you send it to electronics recycling in your area.
Best wishes.
Mar 27, 2018 | Kitchen Appliances - Others
Hp laserjet 1010 red light always blinking, cannot print
Try disconnecting power (not just shutting it off) and data input. Reconnect power and start over again. Something else to check: Look at device status. There may be documents jammed up in queue. I had to abandon my 1010 when upgrading to Windows 10; there was no compatible driver!
Mar 18, 2017 | HP LaserJet 1010 Printer
I lost my instlation driver of colorvis cvc-1010 pc camera
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 16, 2012 | PC Concepts 300K Webcam
I dont have the hp printer 1010 drive for windows 7
Go to the link below and look for driver.
Download the file that has a size of 54.8mb
This would probably get your software installed however you do have windows 7 which has drivers for all printers go ahead and power on the printer ,plug in the printer.Now in control panel open device and printers and click on add a printer select the port(USB) click on next and under Hewlett Packard select your printer and click on next ,again next and finish the installation ,presto you should have your printer installed perfectly now.Please understand your printer is pretty old and if u call in HP they will give you an upgrade option with a 60/70% discount so you can try the above if it doesn't work then please call in at 1800-474-6836 and see what other options you have
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=306507&prodTypeId=18972&prodSeriesId=306505&swLang=8&taskId=135&swEnvOID=228#780
Oct 04, 2010 | HP LaserJet 1010 Printer
Would like toknow how to clean and oil my elna 1010
http://www.scribd.com/doc/3714472/Elna-1010-Manual
page 34 shows some oil use.
older models have a "red dot" to show you where to put 1-2 drops of oil per month (depending on your use)
Jan 26, 2010 | Elna 1010
I cant find a manual online for my bellsouth 1010 2 way radio
Bell South no longer supports the 1010, but I have an owner's manual and can scan it for you. Send me an e-mail at teda1@att.net and I'll send it your way.
Jun 03, 2009 | BellSouth 1010PR (14 Channels) 2-Way Radio
Hp 1010 device driver
you did'nt tell us which operating system, here is the link where you can download the driver.
select the right OS.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=306507&taskId=135&prodTypeId=18972&prodSeriesId=306505&submit.y=0&submit.x=0&lang=en&cc=us
Mar 23, 2009 | HP LaserJet 1010 Printer
I have an olympus stylus 1010 and know how to delete pics individually, but how can i do an automatic delete of all pics on my camera? thanks!
If you have the user manual you can refer to page 33 where it talks about the All Erase function. Or you can just format the memory card which is a permanent deletion of all of the images that have been written to the memory card.
Dec 05, 2008 | Olympus Stylus 1010 Digital Camera
Laserjet 1010
Hp 1010 printer driver downlod free
Aug 20, 2008 | HP LaserJet 1010 Printer
Radio Communications Logo
29 people viewed this question
Top BellSouth Radio Communications Experts
Steve
ka4iup
ka4iup
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
