Question about Bosch Nexxt WTMC3321US Electric Dryer
Door will not stay shut
Dryer door will not latch closed. Dryer still runs but am having to prop something up against it to keep it from opening.
    Top Expert:
  • Bosch Master
  • 12,962 Answers
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Posted on Nov 23, 2013
2 Suggested Answers
  • 3074 Answers
SOURCE: door latch is broken. Door
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Posted on Jan 10, 2011
Gold series dishwasher door won't latch shut.
take a look here with the model #
www.repairclinic.com.
probably a bad latch.
Mar 17, 2018 | Dishwashers
When i open the game i have massge error during Bable initialistion
Instructions
Things You'll Need:
* Electrical tape
* Wooden dowel
* String
1. Place a strip of electrical tape over the latch of the dryer. If your dryer loads from the front, simply locate the latch and place a strip of electrical tape over it. This will stop the door from "catching."
2. Put a wooden dowel on the base of your top loading dryer and prop open the top, the same way you open the hood of your car. This will keep the dryer door open quite easily.
3. Tie a piece of string to the knob on the dryer door. Then tie the other end of the string to something else sturdy in your laundry room. Make sure the string is taut. This will also keep your dryer door open.
Feb 22, 2011 | Dryers
Dryer door won't stay shut latch won't catch
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
May 06, 2010 | Whirlpool LEN2000PW Dryer
I HAVE A KENMORE 90 SERIES AND THE DOOR KEEPS ON OPENING, SO I TOOK ALL OF THE CLOTHES OUT TO SEE IF THERE WAS TO MUCH IN IT, AND EVEN WITH NO CLOTHES IT OPENS?? IT DOSENT APPEAR ANYTHING IS BLOCKING THE...
Inspect the door and when you open it, does the latch hold the door closed? If not the dryer door / latch may need to be replaced.
But check the door as it opens... the door hinges may have been damaged, causing the door to not close properly and the latch may not be damaged, only the hinges.
Good Luck!
Jan 03, 2010 | Kenmore 62602 Electric Dryer
The dryer door will not stay closed. It will actually close but it will not stay closed therefore it stops during the cycle. It we prop something against the door it will stay closed and a full drying...
Go to www.appliancepartspros.com do a search using the model number and you will find the schematics for the dryer. Look for the cabinet parts diagram and locate the latch assembly. Look for the door latch and the door catch both parts will probably cost less than $10. There may be some minor disassembly required but not a big ordeal.
Nov 22, 2009 | Dryers
Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
May 29, 2009 | 2008 Chevrolet Hhr
Dryer door opens by itself after a few seconds
If you are drying very large loads the door could be popping open from weight against it, not the most likely source of problem. Most likely latch is getting worn out and needs replaced.
Apr 26, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Bosch Nexxt WTMC3321US Electric Dryer Logo
174 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
