Question about Clothing Accessories
Supreme weigh pocket scale sw13 displays HHH - Clothing Accessories
SOURCE: Avery H500/L200 Avery Weighing Scales For
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Posted on Apr 15, 2012
mrstanskaggs
  • 118 Answers
SOURCE: How do I fix a manlloro digital pocket scale when
I thinkn there is a reset button to press with no weight on the scale if I remember correctly. Might have to calibrate with the test weight too if the calibration is messed up (not likely though).
Posted on Jan 03, 2015
  • 42976 Answers
SOURCE: My supreme weigh digital jewelry scales model #SW09 is reading LLL. What does that mean and how do i fix it?
It could be indicating that the battery is low.
Posted on Feb 06, 2015
  • 42976 Answers
SOURCE: My supreme weigh digital pocket scales is reading LLL? What does that mean and how do i fix it?
The LLL reading probably indicates a low battery.
andrewl901
  • 505 Answers
SOURCE: my scale reads HHH when turned on. How do I correct this problem?
There is a similar problem on this site and solution.
My digiweigh scale reads HHH What does this mean and how do fix it
Posted on Feb 09, 2015
How do I fix a manlloro digital pocket scale when it reads HHH?
Jan 03, 2015 | Health & Beauty
I have a supreme weigh sw02 digital pocket scale i need to calibrate and need help
500ml 0f water is exactly 500g, measure that volume and put it in freezer bag and use as calibration weight, or if you have friend with scales - borrow from him scale weights.
if you use water - accuracy of the scale will not be absolute, it may vary few g either way.
another way - go to shop and buy 500g block of butter - put it on the scale in the shop - remove or add as you need till you have exact 500g, shop scales are accurate on that weight within 2g
do not forget to vote if you find this answer useful...
Jan 02, 2015 | Health & Beauty
Y does my scale model # sw13 read LLL
That means that it is out of range. It is trying to weigh something that is too light. IT could be the sensor is bad or loose.
Oct 31, 2014 | Health & Beauty
Envelope postal scales by pelouse
go to a tobacco shop or a tobacco pipe shop"head shop",or ebay, Vintage Pocket Hand Held Postal Scale 0 2oz ,or here, Postal Scales Hand Held Scales , or, Items found similar to Hand held pocket postal scale keychain 100 grams... good luck,most staples will not sell them because they are commonly used to weigh drugs.
May 21, 2014 | RTO Pelouze Scale With Remote Display -...
Sw13 scale reads HHH
Most likely HHH represents an error message telling you the weight of them item is higher than the scale can handle. For example if you had a very sensitive scale that weighed up to 50 carats and you put a 250 carats ring on the scale, it would give you an over load error message.
May 17, 2014 | NATASHA COLLIS Gold nugget ring with mixed...
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
Oct 14, 2012 | Health & Beauty
Clothing Accessories Logo
290 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
