Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidare range error codef20 - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • 54 Answers
If you didn't replace any elements, then it is the control panel. If you did here is a post I found on it: On a service call i ran across this same range with the same problem and remembering from a s/c about a year ago i had purchased the (316441801) dual element switch .. It wasn't in a box but looked the same . so i installed the switch .. and to my surprise f20 popped up as soon as I turned on the oven . This code also appeared when i removed and isolated the wire's ( i.e. no switch at all ) I spent the next 30 minutes checking wiring , so here's the reason this happens . It is a communication error code . One of the Dual elements has a (316441801) and the other has (316441804) switch . The last number is different . I found that one switch acts as a ground and the other as a positive , if you will.and I'm not quite sure as to why its attached to the EOC . So when changing out one of the dual switches look at the sticker on the switch ( hehe which I didn't)as it has the part number on it . Hope this helps and saves someone from buying the EOC as that is most likely not the problem
Posted on Nov 23, 2013
My frigidare oven shows f11
Hello Jaime, I am happy to assist you!
Typically error code F11 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Best regards!
Feb 05, 2014 | Frigidaire Ovens
F20 error code on Frigidare electric range
Hello rjshomesnj - Typically error code E20 indicates that the range has detected a communication failure between EOC (electronic oven control) and ESEC system (electronic service element control). In other words, the range has an issue with the switch for the burner. I will personally recommend contacting a certified technician to move forward accurately and to assist with the repairs. You can often locate qualified servicers by visiting the manufacturer website.
Mar 01, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Where is the control board plug on frigidare stove
Hello meikle1961 - Do you have exact model number to the unit? Are you speaking about a gas or electric range? Reason I ask is because depending on the model number, there are various controls on some ranges. With this information I can assist you better in pinpointing you the part location.
Oct 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidare brand self cleaning gas range and the oven will not light
If the rest of the unit work properly, then you are having an electronic ignition issue. Contact your manufacturer and then a professional they suggest to have it repaired.
Sep 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
DISPLAY ON FRIGERDARE STOVE DOES NOT WORK
HI. Kindly unplug the unit for five minutes. Once the five minutes are up, simply re-connect power to the unit, and try to start a baking cycle. If the display continues to not function, this will confirm that the main control board has failed.
This type of failure will require you to replace this damaged control board, asap.
Dec 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
Dec 19, 2007 | Frigidare FGB24S5DC Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
48 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
