Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA71 NOT DEFROSTING
COMPRESSOR AND FAN RUNNING. ICE BUILD UP AT THE BACK
    Top Expert:
  • Hotpoint Master
  • 12,962 Answers
Self defrosting feature is not working. Check defrost thermostat, defrost heater, defrost timer for proper operation.
Until repair is made, defrost the unit and turn back on until it freezes up again. Check the ice block at rear of freezer. If the ice is confined to the area around the refrigeration line coming into the freezer it is low refrigerant level. If the block completely covers the evaporator it is a non working defrost mechanism.
Posted on Nov 23, 2013
  • 17 Answers
SOURCE: hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
Posted on Dec 10, 2007
  • 1150 Answers
SOURCE: fan oscillation
Probably damaged the fan blade. If plastic, it could be missing a blade or maybe cracked. If metal, probably bent. I would ttry to get an eyeball on it while it''s running to see just what's up. Fan motors are usually pretty durable and last quite awhile.Good Luck and hope this helps.
Posted on Mar 15, 2009
SOURCE: Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Posted on Jul 11, 2009
imufo2
  • 3773 Answers
SOURCE: we have a hotpoint ffa71
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 03, 2011
  • 16 Answers
SOURCE: I have a Hotpoint HSS25GFPEWW side by side.....
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Posted on Aug 15, 2012
My Hotpoint refrigerator is not staying cool and the freezer is not keeping things frozen.
Is there ice accumulation on the back wall of freezer? If so the auto defrost mechanism consisting of defrost timer, heat element, defrost timer is defective.
Is your thermostat working properly and not turning things off prematurely?
Freezer fan spinning?
Compressor running?
Check out the above.
Sep 09, 2015 | Hotpoint Refrigerators
Condenser fan making noise and sometimes makes a clicking noise coming from electrical board on back
are u sure the noise is from the condenser fan and not the capacitor near compressor? the fan in freezer is making noise usually due to bad impeller or blocked bcuz of ice build up due to defrost problem?
Apr 12, 2015 | Hotpoint HSS25GFP Side by Side...
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
Hotpoint refrigerator has power but not cooling
Hello there,
If your refrigerator is working perfectly fine but is not cooling. Check the compressor if it is running as well as the fan, then you check if the condenser coil is not clogged, then you check for ice build up at the back of the unit. If they are working and there is no ice build up, then it means the problem is from either the defrost thermostat, defrost heater the door switch or the defrost timer.
You will have to test and replace the faulty component. But if the test is carried out and the components seem to be in good condition, then it means, the refrigerator is out of gas and that simply means you will have to refill the gas tank.
Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
You can have some to assist you if you are not familiar with sich technical activity.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge/freezer not cold. Fan or compressor not running....
possibly main pcb faulty but may just be in defrost mode where the fan and compressor will not run . In which case the ice build up will be due to faulty defrost heater or stat
Jun 14, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
80 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
