Question about Olympus SP-590 UZ Digital Camera
Camera doesn't turn on
When i turn on the camera, i just see the 'olympus' writing in the screen only for a second, and then the screen becomes black so the camera doesn't work. lens don't show up, but i hear the auto zooming sounds and vibrations in the camera. do i have a chance to reset it? if not, what should i do?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Sounds like a firmware problem.
What happens when you plug it via USB to your computer and run the corresponding software? Does the software detect your camera? If the sofware has a "firmware update" button try it. You might as well download a firmware update from the brand webpage, unzip it and copy it onto the root (main folder, no subs) of the storage card and boot up your camera.
If your camera has detachable lenses, have you tried turning it on without it?. Also, for the update uptions, I would try them wihtout lenses (since they sometimes have their own firmawre).
Hope any of this helps.
Posted on Nov 21, 2013
SOURCE: Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Posted on May 02, 2009
  • 11967 Answers
SOURCE: My Olympus FE-320 will not focus. When I turn the
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 22, 2009
  • 11967 Answers
SOURCE: lens is stuck in full zoom position Olympus 7010 camera
Posted on Dec 10, 2009
  • 11967 Answers
SOURCE: My Olympus SP-550UZ 18x optical zoom has a
Posted on Dec 29, 2009
  • 11967 Answers
SOURCE: Zoom error on screen and shuts off
Posted on Mar 25, 2010
Olympus TG-320 camera won't turn on
It's a high probability that the waterproof seal leaked and the water is making it's way through the system shorting various components.
Diane
NYC Photo Safari
Feb 18, 2014 | Olympus Tough Tg-320 14 Megapixel Compact...
Olympus VR-340 Won't turn on, lens won't retract.
My camera vr-340, when starts a sound appear and sacreen becomes black . what is this?
Jun 20, 2012 | Olympus Vr-340 16mp Camera Digital Optical...
My olympus fe 4040 has folled on the sand, and now the screen is black, it doesn't turn on and the optic doesn't come back, it still in the middle, do you think that the sand get inside it?
maybe the sand is getting inside or stucked in your camera body. you need take them out,or it will affect the normal working of other parts.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Aug 31, 2011 | Cameras
My Olympus FE 340 Camera firmware is crashed.Hardware is ok.Menu functions are OK.but when Im taking photo Screen is only dark black and shoting photos are same.I cant upgrade the firmware as My camera has...
I have a similar problem in the same camera: all hardware is ok but it doesn't focus. I've taked out the focus motor and it works, and all the pieces works too, they're not damaged, in fact wth the motor out I can focus manualy the picture. So I think it could be a firmware problem, but the OLYMPUS software doesn't leave me to write the same version of firmware, and there's no new versions, so is there any way to rewrite the same version of fw????? any service program?
Aug 26, 2011 | Olympus FE-340 Digital Camera
My olympus camera (FE- 330) froze when i tried to deleted photo and the the camera froze and the screen is now black and the lens are sticking out
Try inserting a fully charged battery.
If that doesn't work; you may need a new battery.
Write back if none of these work.
Dec 29, 2010 | Olympus FE-330 Digital Camera
My Olympus Stylus 7010 was working fine until yesterday, screen has warning sign saying Write protect
wen i bought my olympus stylus 7010 the number of pictures that can be save was 9999 and wen im taking pictures it doesn' tchange but after saving at least 1000++ pictures there are only 1800+++ remaining memory.. how can i have the same 9999 memory???
Jun 27, 2010 | Olympus Stylus 710 Digital Camera
Screen on my olympus stylus 830 went black
You do have a one year factory warranty from date of purchase - suggestion is to send it in for evaluation as it could be a problem with the chip inside the camera that controls image processing. It sounds like that chip may need to be replaced. You can call Olympus Customer Service at 800-622-6372 option 2 and then option 3 to discuss the repair process with them.
Jan 09, 2009 | Olympus Stylus 830 Digital Camera
Olympus camera error
something is causing the camera to not boot up properly whether it is the lens or something else.. you may try to power reset... hold down the power button for 10 seconds while the battery is out of the camera
Sep 04, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus SP-590 UZ Digital Camera Logo
60 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
