Question about HEWLETT-PACKARD Elitebook 8460P
Wifi miniport adapter missing
I am unable to connect to the hot-spot from my Lumia. It says that my computer did not respond. However, 'netsh wlan show hostednetwork' shows 'one authenticated user'
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Are you trying to use something like VirtualRouter? I have had some trouble with these programs especially with Win7/8 compatibility. Generally I am able to solve them with some troubleshooting but there is not one Fix All. Let me know exactly what software you are using to create the hotspot, as well as what operating system you are using.
Posted on Nov 21, 2013
Testimonial: "I am trying to implement this... http://dottech.org/90970/windows-8-how-to-tether-internet-connection/ I am trying to connect my Lumia 920 to the hosted network on my laptop running windows 8.1."
I need help view viewing a saved wifi password on my nextbook 10.1 intel quadcore tablet. I forgot the password and need it to hook up to my other devices
To view your password you need to open up a command prompt (cmd.exe)
Than type in netsh wlan show profile and press enter. This command will show all of the access point you have connected to in the past
Now type in netsh wlan show profile "your access point SSID without the quote" key=clear and press Enter
example if my SSID is ABCD than I would type it like this
netsh wlan show profile ABCD key=clear
It will show you the password of your access point.
Apr 13, 2017 | Nextbook Tablets & eReaders
I have a surface tablet unable to connect to wi fi
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
Jun 30, 2014 | HP Compaq nc6000 Notebook
How do i pull up "Netsh" on a toshiba laptop?
Assuming you've already confirmed that the toshiba can supported a hosted network ...
to create a hotspot, at the command prompt, type "netsh wlan set hostednetwork mode=allow ssid=yournetworkname key=yournetworkpassword," and hit Enter on your keyboard. Remember, "ssid" refers to the WiFi hotspot's name while "key" is said network's password. You can also use the aforementioned command to change the hotspot's name and password.
To get the hotspot up and running, type "netsh wlan start hostednetwork.
Mar 05, 2014 | Toshiba Computers & Internet
Microsoft Virtual WiFi Miniport Adapter driver for Fujitsu T580
Right click My Computer then select Manage the select Device manager.At this point you need to look for the driver in the network adapters.If you don't have it the download.If you see it Right click and select update driver.
Sep 20, 2012 | Fujitsu Computers & Internet
I have problems connecting to the internet. When I diagnose with windows it says that my computer is correctly configured but the device or resource (DNS server) isn't responding.
1.Open your network connections, If using windows xp click start/run/Type ncpa.cpl hit ok
windows vista/7 click start/search bar/type ncpa.cpl
2.Right click connection you want to connect to and hit properties.
3.Uncheck ivp6 and click on ipv4 to highlight it and hit properties.
4.Ensure obtain ip address automatically is checked as well as obtain dns server automatically. if not check them both and hit ok.
5.If this does not work open your command prompt.To do that click on start/all programs/accessories right click command prompt and hit run as administrator.
6. Once open write the following commands and hit Enter after
1. netsh int ip reset reset.log
2. netsh int ip delete arpcache
3. netsh winsock reset
4. ipconfig /flushdns
Restart your computer
7. If still unable to work, go to Control Panel/Device Manager/scroll down to network adapters/find your network adapter and see if there is an error shown usually you will see yellow question mark or attention mark. If there is right click on your network adapter and hit update driver. If no error shown right click on your network adapter and hit uninstall. Once uninstalled restart your computer again and your computer should recognize your adapter
8. if still unable to access the internet your will need to refer to your manufactor due to bad network adapter. Hope this helps
Sep 09, 2011 | Arris SURFboard SB5120 Modem
The driver installed for microsoft virtual wifi miniport adapter is not working correctly. So, I need a compatible driver and a compatible software for microsoft virtual wifi miniport adapter
Hi
if you go to computer properties
then device manager
find the miniport adapter
un install it
then restart laptop
hopefully windows will reload it on startup
and maybe then it will be ok
if not go to the website of your laptop and download another driver for it
type into your search engine the make of your laptop then search for your model and os
then search for the driver here are a few examples on how to type in your manufacturers web page
www.acer.com www.hp.com www.compaq.com
Apr 24, 2011 | Computers & Internet
Driver for microsoft virtual wifi miniport adapter
Hi brian
microsoft virtual wifi miniport drivers can be found at driverupdate us .
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Jan 05, 2010 | eMachines eMD620-5133 Notebook
About,wifi/WLAN,ACER EXTENSA
801.11 a/b/g WLAN is wireless networking (wifi) and can be used in a wirless hotspot.
Feb 02, 2009 | Acer Extensa 4620 Notebook
HEWLETT-PACKARD Elitebook 8460P Logo
71 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
