Question about Craftsman Garden
How do you adjust the electric clutch 180505 - Craftsman Garden
  • Craftsman Master
  • 2,760 Answers
Depends if it's adjustable or not remove mower deck and look at motor shaft you'll see clutch (it's got a wire going to it) if three springs are held in with rivets then it's not adjustable you'll need to relpace it if it's got three phillips head screws then in a alternate pattern try tighting each one half a turn and test it , if screws bottom out replace clutch
Posted on Nov 23, 2013
Is there any adjustments to the electric clutch on a 2007 John Deere X340? I have a slight noise issue when the clutch is not engaged.
There is no adjustment but the clutch does have a bearing in it that rotates only when it is disengaged. This may be what you are hearing.
Jan 09, 2017 | John Deere Garden
Electric PTO clutch on a LX255 John Deere I want to remove it and disassemble it to repair it
Electric Clutch Adjusting and Troubleshooting for Lawn ...
? 7:05
www.youtube.com/watch?v=yB9Lf_NKYXw
Oct 15, 2011 - Uploaded by askanthonynow This video describes how to adjust an electric clutch on a lawnmower. ... How To Repair Ripped Out Wires On An ElectricalPTO Blade Clutch - Duration: ... John Deere: How to change bearings in the deck spindles - Duration: .
Aug 25, 2015 | Garden
Electric pto wii not engage?
how do you know it's actually getting to the clutch ???
is there a ground for the clutch too ???
is the clutch adjustable ???
Aug 29, 2014 | Garden
2002 yz 125 when I put it in gear it will shut off acts like the clutch is not working when I adjust it on the handle bars it slips
Mechanical issue: clutch not disengaging completely...
engine off - put in gear and roll back and forth with clutch released does engine stop the bike from rolling? Now pull clutch lever in and try rolling again is clutch cable adjusted properly?
Electrical issue: bike thinks clutch is still engaged and kills motor when not in neutral
Is the clutch switch properly connected and working? Is it adjusted properly? Use a multimeter to read resistance across switch contacts does it change state when clutch is pulled in?
Jul 28, 2014 | Motorcycles
What is the clutch adjustment for 2003 HD Electric Glide Classic
To adjust the clutch, follow the clutch cable until you find the cable adjuster. Move the adjuster cover up or down to expose the adjuster. Loosen the lock nut and adjust the adjuster to get as much slack as possible.
Now, remove the derby cover. Loosen the locknut in center of the clutch assembly. Turn the center bolt inwards until you feel a resistance. Do not force the bolt, just turn it inward until you feel a resistance. Then back the bolt back out 1/2 turn and lock the locknut. Replace the derby cover.
Now, go back to the cable adjuster and adjust it back out until you have about 1/8" freeplay. Squeeze the clutch lever a few times and recheck the freeplay. Lock the locknut and replace the cover.
Good Luck
Steve
Jan 10, 2011 | Harley Davidson FLHTC Electra Glide...
Can you adjust clutch 16"homelite electric saw
There is not a clutch on an electric chain saw, it is direct drive when the electric motor ia activated. If the chain is binding it will stop the chain.
Nov 03, 2010 | Homelite Electric Chain Saw
Have a 1999 suzuki vs800. Starts fine Idles fine, now that I adjusted that, and all lights and everything work. Moment I clutch in and shift it stalls out. Is it the clutch cable the clutch something...
your clutch may be burnt up, but try adjusting the clutch cable out a little more, or if you have a hydraulic clutch fill it with fluid and prime it.
Sep 03, 2010 | 1999 Suzuki VZ 800 Marauder
John deere 240 brand new electric clutch. went I throw the swtich it clicks but doesn't engage....
Adjust the clearance between the plates,9/16 wrench and turn the three nuts on the clutch one at a time about 1/4 turn each,retry the clutch,repeat until it works normally.
Jan 08, 2010 | Oregon Scientific Electric PTO Clutch for...
Electric clutch adjustment
.012" is the recommended air gap for the electric clutch. Use a feeler guage in the slots beside the nuts and check in circular pattern. Go at least 3 complete circles with your guage when adjusting.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Simplicity sunstar 20hp rear pto won't engage deck when you flip the switch, it used to work for a while and I could play with it and it would work but now nothing, any suggestions.
your electric clutch may need adjustment. Take the hood off. Look behind the double pulley that's on the crank shaft. Behind the pulley is an electric clutch. You will need a .010-.015 feeler gage and check between the clutch plates. You will tighten the three screws that mount the clutch to the motor. Try and get as close to .010" as you can. After adjustment start the motor and try and engage the pto. I bet it will work.
Good luck
Jul 18, 2009 | Garden
Garden Logo
59 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
