Question about Dryers
Can you suggest how to replace a glass lens on a unit that is no longer availavable without having to replace the whole unit.
    New Friend:
  • 92 Answers
If you know the model it would be helpful
You could consult the manual here
Posted on Dec 20, 2013
My lights are very dim will cleaning the lens work and what do I use
first fit new bulbs
and check the earth contacts
if still dim
if they lenses are plastic and clouding over
there is a very fine grit sandpaper kit you can buy
or try heaps of toothpaste and paper towel
..takes a lot of effort either way to get them clear again
cheaper than replacing the whole light unit
if typical glass lens
take the whole light unit off the car take the bulbs out
into the dishwasher
windex and paper towel
vinegar and water
Oct 14, 2016 | Cars & Trucks
Can the headlight lens be replaced on a Hyundai Matrix 2004 1.6 Petrol without having to replace the whole assembly?
No the whole assembly is called the lens and the front glass/clear lens is a part of that. They are not that expensive in the aftermarket, do a google search for sources, 1Aauto.com is one place i use, about half what the factory part costs.
May 27, 2012 | Cars & Trucks
I have an LG air conditioner, Model LWHD800R. The power chord has an adaptor with two re-set buttons which plugs into the wall. Both of these re-set buttons no longer work. Without the re-set feature, I...
Just replace the cord. I am unfamiliar with your unit so you may need to buy a new cord form the manufacturer but there is no reason to replace the whole unit.
Jun 16, 2011 | LG Heating & Cooling
I dropped my camera and the glass on the front lens is cracked so the pictures have a glare on them. IS this replaceable?
Not really, but there are a lot of T1s with dead CCDs and boards on ebay - you could get one (for like $10-15 and replace the whole lens unit). Hope this helps (somehow).
Jan 24, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
I have moisture on the inside of the headlight lens. How can I get rid of it without buying a whole new headlight lens assembly?
Just a suggestion, remove the light assembly, remove one bulb, blow air into the unit, see where the air leaks out, seal it with Goop. Quick and easy.
Dec 25, 2010 | 2001 BMW Z3
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Feb 08, 2009 | Samsung BD-P1400 Blu-Ray Player
Replace real light assemble passenger side
Just replace the glass it should come with a seal.
Feb 10, 2018 | 2002 Lexus ES 300
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Not printing all text
If you blank stripes in the vertical plane, it would suggest that toner or other foreign material has got onto the laser lens. Remover the toner and photo conductor units and look for the glass panel above the laser unit. Clean this with a tissue or soft cloth. You should find this gets you away. If not then the photo conductor is the next suspect to replace.
Sep 16, 2007 | HP LaserJet 2100 Printer
Dryers Logo
131 people viewed this question
Top Dryers Experts
