Question about Radio Communications
I bought a new 510 plus. When I switch it on, the screen looks normal for 1 second then fades. Tried new batteries. Store went out of business. No response from Forus website.
510 plus
snakehead
  • 1074 Answers
SOURCE: Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Posted on Apr 26, 2007
SOURCE: FL-36 flash
It's my experience that the contacts down at the bottom of the battery compartment corrode easily. Clean them with electronic contact cleaner and a swab and they should work again - for a while.
Posted on Aug 12, 2008
Nobarai
  • 57 Answers
SOURCE: TI-83 Plus Went Dead
Has it been dropped recently? The screen may have cracked from impact. Press the Reset button on the back using a ball point pen.
Posted on Nov 16, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I bought a new, or looks like new, Breadman Plus
This site has a TR777 manual listed for download. It may not be exactly the same as a TR777C, but it will probably get you going. They also list a phone number so you can try getting manuals direct from the manufacturer.
Posted on Mar 18, 2010
Testimonial: "Thanks so much. I downloaded the file, and it should be exactly what I need. "
wd4ity
  • 4565 Answers
SOURCE: Attempted to start , pushed start button , engine
Ok, make sure your battery is installed and connected correctly. The connections should be clean and tight. Now, look at the end of your starter. You'll see a five sided plate with a tower like thing in the middle on the end of your starter. Just above it is a single wire that plugs onto the starter. Unplug this wire and insert a test light into the wire. Turn your ignition on and press the start button. If the light lights up, your starter is bad. If it doesn, you've got another problem.
If the light does not light up, you'll have to find the starter relay. Harley moves these things around all the time so you never know where to look for one from year to year. I'd start under the seat and then move to the side panels if necessary. The relay is a typical one inch cube made of plastic. When you find it, turn on the igntion and press the start button while holding the relay. It should click. If if doesn't, it's probably bad and even if it does, it's probably bad. I'd replace the part as it's not all that expensive.
If you suspect the starter, go back and remove the three screws that hold the five sided plate onto the starter. Behind the plate you see a plunger with a spring on it. NOW, MAKE SURE THE TRANSMISSION IS OUT OF GEAR. Using a large screwdriver, push the plunger into the starter as far as it will go. The starter should engage and turn the engine. If not, you may have to replace the large copper contacts in the solenoid.
I hope this helps you find and fix your problem
Ride Safe
Steve
Posted on Jan 02, 2011
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
UNIT LOCKED NEED CLEAR AND RESTORE DEFAULT PASSWORD TO 1 ALPHA ALPHA66831
we have olivetti pr2 plus printer all station 1 station 2 light binking .please help me urgent .
Jan 09, 2013 | VeriFone VX 510 Credit Card Terminal
Have just bought sim free nokia 3720 classic and it won't stay swiched on for more than a couple of seconds .the screen just fades out and it swiches itself off .it won't even work in sim free mode...as...
check your battery maybe its low bat or worn out.try other battery. if its still the same. your phone needs to be reformat or reprogram by a qualified service techn
Nov 27, 2009 | Nokia N70 Cellular Phone
Blackberry pearl wont switch on
It looks battery completly drained and dead (as It took so much time), the best way first to check "Circuit" status in Battery through Voltmeter (poles)..or another way go to any cell phone shop and give a trial with another batterty to check status of your unit.
Aug 23, 2009 | RIM BlackBerry Pearl 8100
1980 datsun 510
is it the battery...
it sounds like the alternator might have gone out...
does it crank?
Mar 24, 2009 | 2003 Datsun 510
Tomtom 510 doesn't reset
Before you keep resetting your tomtom I would intall a new battery. Call your closest "batteries plus store" or "radioshack store" and then try to reset it, it might be only the battery and nothing to do with the reseting.....
Mar 24, 2009 | Tomtom GO 510 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Apr 25, 2007 | Grundig GF70-600 TV
Camera turns off even with new batteries in it. help pls.
Hi gras, [Samsung Digimax 301] My camera also went dead on me, just can not turn it on. Please help with instruction on how to open it. I have removed 10 screws but the camera can not open completly.
Aug 07, 2006 | Samsung Digimax 301 Digital Camera
Radio Communications Logo
12 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
