Question about Dell Inspiron 700M Notebook
Jeep key says damaged - Dell Inspiron 700M Notebook
Why wontmy keyless remote start my jeep
You need a specialist or a dealer. Try the Jeep owners club website or forums to see if someone has had the same problem. If you need a new key and receiver, be sitting down when they tell you the price!!
Oct 20, 2014 | Cars & Trucks
What to do with damaged key indicator for 2008 jeep commander?
did you use both sets if keys, as car came with new?
or running naked, 1 key?
try the other key.
if you lost the backup, then it\'s.
  1. Dealer time. (towed)
  2. ASE shop time (same)
  3. or call the mobile lock smith that does CARs.
Sep 03, 2014 | 2008 Jeep Commander 3.7
1998 jeep tailgate won't unlock
bad lock, or its jammed some how,
the key has to work.
replace the lock. or get a lock smith to fix it.
Id pull the skins and check it very carefully , even remove it
and make sure its not damaged somehow, ice damaged, last winter.
and progressed to worse. most damage does that.
just to be sure, make sure its not in child safe mode.
did you read the operators guide, on that?
Jun 30, 2014 | 1998 Jeep Grand Cherokee
My jeep will not crank, says key failure
IT is probably refering to the fact that the immobiliser is not recognising you key. Check the key battery is ok The key damage will be a fault in the remote part of the key and not to physical damage that you can see.
Dec 22, 2013 | Jeep Cars & Trucks
Jeep Grand Cherokee key damage
i think the dealer has to reprogram this.
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
Have a 2008 jeep grand cherokee laredo put key in ignition and dash board says damaged key and another service security key jeep wont start
This sounds like a bad chip in the key, try a spare key, if it starts with spare key then key is bad, if it doesnt start then you will need reprograming
Oct 01, 2010 | 2008 Jeep Cherokee Grand
Parked my jeep at the mall when I came out the key would not turn in the ignition and the breaks are locked. it a 2007 Sahara
the keys on the newer jeeps have computer chips in them. the chip may have been damaged try your spare key if that solves the issue becarfule with that spare key cause replacment keys are very spendy
Jun 27, 2010 | 2008 Jeep Wrangler
2005 Grand Cherokee: the key worked up untill now 2005 jeep grand chero...
if the key has been dropped or kept near a high magnetic item (a tv screen)it will go out,use the spare until you can get all keys reprogrammed together
May 06, 2010 | 2005 Jeep Grand Cherokee
Dell Inspiron 700M Notebook Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
