Question about Husqvarna 12 Cutoff Saw K760-12
K760 saw repair manual
Please could some one tell me where i can get a repair workshop manual from thanks you
Saw starts, but why does it run few seconds then quit?
Has it enough compression ? because i have the experience it have a questionable closing system for carburetor air filter it is not always fully locked take care to close it replace parts if its not as soon as this problem is there or its to late , on the way it should but when it is not good closed it leaks in much cases and the piston had often grooves by polution from graveldust it can have lost compression by it first to do is control the piston.
In the event that all of this is not the subject the tank airiation and fuelhoses to control.
51MM Cylinder Piston Kit For HUSQVARNA PARTNER K750 K760 REP 506 38 61 71
Feb 11, 2016 | Husqvarna K760 Cut-off Saw,2-cycle...
Why is throttle stuck wide open?
Could be a couple of things. could be a return spring sticking on the carb, or the throttle cable has frayed and sticking on. I've added the breakdown manual for you.
http://www.mediafire.com/download/68zm589mejh8jnq
Dec 20, 2015 | Husqvarna-Target Husqvarna K760 14 Inch...
How to replacethe primer bulb
look only the brand and numbers of the used carburetor WALBRO most of the times or ZAMA the model
FIND PARTS FAST look there
Sep 11, 2015 | Husqvarna K760 Cut-off Saw,2-cycle...
Huskvarna k760 20011 wont start. oil in de compresor switch n spark plug hole.!??
Check and see if you put the bar oil into the gas tank by accident the last time that you filled it up. Get back to me about this please.
Apr 03, 2015 | Saws
Saw runs at normal idle with choke pulled and wide open with choke off
I would take it back to the repair person you used and let them know that they fixed one problem and caused another.
Jul 09, 2014 | Husqvarna 12"" K760 Concrete Saw"
I have a husqvarna 350 that wont start, wondering if anyone can tell me what is the factory compression rating?
Hi and welcome to FixYa, I am Kelly You should have 120 PSI or greater compression. There is a ported compression release so you may see as little as 110 PSI but it is best to see 120 or greater.
The Owners manual is here:
http://www.northerntool.com/downloads/manuals/195946.pdf
carb basic settings are on page 29 of the manual.
The saw has a Zama C3-EL18 carb.
The manual for the carb is here:
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf (Click and wait 2.50 mb)
Your carb is the C3
The workshop manual for the saw is here:
http://www.scribd.com/doc/8152011/Husqvarna-Chainsaw-Workshop-Manual-340345346XP350351353 (Must have a facebook account to download but can be viewed online)
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
One question, im looking to buy a husqvarna k760 demo saw, i need to cut metal, such as truck and trailer frames. just need to cut them down to length so i can load and bring to scrap yard. i figure it...
The K760 black cutter blade is called a Cut-n-Break blade. The manufacturer states that it has an improved stable core to increase its performance. I have a friend who recycles scrap metal and uses the Mastercraft 5" dual cutter. It cuts through metal like butter without any kickback.
Hope this helps,
Handie Andie
Mar 26, 2011 | Husqvarna Garden
Husqvarna 12 Cutoff Saw K760-12 Logo
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ken skalski
rdjagger
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
