Sony trinitron When I press the power button on my tv or remote, the tv clicks but doesn't come on.
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Something short circuited component at it main power regulator or horizontal scan output section circuit. Check it. To get more details, http://electronicshelponline.blogspot.com/
Posted on Nov 22, 2013
techman
  • 3130 Answers
SOURCE: sony trinitron KV G21S2(i think)
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Posted on Jun 23, 2007
  • 20 Answers
SOURCE: Sony Trinitron Tv
Dear sammy5,
Stop by any TV repair shop in your area, and ask to borrow a used original Sony remote, they may require a small deposit; access the menu, perform your set up, then return it. Or you could buy a universal Sony remote from Walmart that should work just fine, for about. $7.00.
Hope this helps.
Richard
Posted on Nov 08, 2007
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
joez47
  • 61 Answers
SOURCE: Sony Trinitron TV sap button got pressed and don't
You should be able to find the SAP, Normal Audio option in the Audio Set-up or Options sections when you select Menu.
Posted on Aug 29, 2009
  • 1274 Answers
SOURCE: Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Posted on Feb 17, 2010
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Turn telly on, no sound, no picture, its a sony trinitron tv type kv-28fx20u
If standby light on tv is not blinking that means tv needs power up command either by remote or power button on tv itself.
Press Program +/- button on tv front to turn On tv.
Thanks.
Dec 25, 2010 | Sony Televison & Video
My sony trinitron tv wont turn on. it blinks 4 times on standby. what do i do
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
Aug 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Video 1 wont go off
If you have a cox cable digital cable remote, hit info to turn off the video 1 or 2. Judjing that this is a cox cable remote, and not a sony trinitron remote, other remotes that have some kind of programmable function built in can proly turn turn that off
Dec 25, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
PROGRAMMING REMOTE
you have remote code together you bought a remote control,scan the page of the remote guide book, select TV look the number according to your TV Model there are one or three group of number .
press power,press tv enter code # press enter ,aim to the TV front .If the channel appear means the program activate the TV set.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
