Question about Maytag MED9700S Electric Dryer
Med9700sbo powers up but motor will not run
The dryer comes on like it should, drum light works like it should, but, when you press start, there is a click like normal but, nothing else happens. The motor is not engaging. I changed out the motor, checked the thermistor and thermal fuse. Also, the new motor came with a new dryer belt switch. I put it back together and it's doing the same thing. I didn't see any noticeable burn marks on the mother board. What do you think?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Be sure the door switch is working
Posted on Nov 22, 2013
SOURCE: Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Posted on Jan 23, 2007
the dr
  • 447 Answers
SOURCE: MAYTAG DRYER MDE5500AYW
Have you checked the door switch, thermal fuse on the heater housing(this will keep it from starting).
Posted on Oct 06, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
Greg20
  • 149 Answers
SOURCE: My dryer quit working and I think it is the thermal fuse.
maytag neptune?..remove door and screws on other side too.. pop off front. :)
Posted on Jun 14, 2009
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
I CHANGED DRUM SUPPORT ROLLERS AND PUT BACK TOGETHER AN IT WILL NOT START
Suggest the following.
  • Check drum light. No light defective door switch. Light yes one leg of 220 circuit OK.
  • Be very sure motor doesn't start when you set to run. Belt may be off the motor and motor is very quite. Fix belt. Motor may be stuck or failed listen to hear if it is buzzing
  • When pressing start button listen for distinctive run relay activation. If when the start button is depressed I would expect to here the relay.
  • Motor run circuit relatively simple. The drum motor and blower are one assembly.
Nov 30, 2015 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Admiral dryer wont come on
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 01, 2012 | Admiral Dryers
Dryer has power. control lights working. when you press the start button the only sound is a humming noise. will not start.
Check your drive belt which is located around the outside of the drum. The "hummmm" you hear sounds like the motor running. Normaly this motor provides the power to the belt which surrounds the outer surface of the drum (where u put the cloths)........ the belt wraps around the outside of the drum, then around a small pully mounted on the shaft of an electrical motor normally located just below the drum on the inside of the outer enclosure. This motor will be mounted to the the dryer's frame by a mounting plate. This motor mounting plate will pivot (like a hinge)..... it will also have an extension spring hooked to it which provides tension to the drive belt when properly looped around the pulley on the drive motor. When the belt breaks or snaps....... the drum stops spinning..... however the drive motor still runs. Thats the noise you hear! Diss-assemble outer sheet metal providing access to drive belt and replace with correct belt recommended for your model dryer. Caution should be used during repair........ ALWAYS UNPLUG POWER CORD PRIOR TO SERVICING ALL/ANY APPLIANCE's !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 14, 2011 | Frigidaire AEQ8000FG Dryer
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Dryer won't turn on - interior light on
It sounds like you have either a broken drum belt or a door switch that isn't working. If the dryer belt breaks, the drum will not turn, but you will probably still hear the motor running. I don't think your model has a broken belt switch that disables the motor (at least I couldn't find one). You didn't mention anything about hearing a motor running, either. The likely cause, then. would be a door switch. If the switch was not making contact when the door was closed, it would give the very same symptoms you described. Have you tried pushing on the switch with the door open to see if the drum light goes out? If the light DOES go out, we probably have a primary power problem to the drive motor. If the light DOES NOT go out, replace the door switch. You can find the part at searspartsdirect.com. Just type in your model number and you can locate the switch under the "Cabinet Parts" heading as item number 10 (part #3406107). Let me know how you diagnose this and get back to me. If it is the switch, I can give you steps on how to replace it. If its not, then we'll have to troubleshoot a little further. I'm trying the simple approach first before attempting to disassemble the dryer. I hope this helps you.
Jul 03, 2008 | Whirlpool LER5636P Electric Dryer
Dryer will not turn on
IT COULD BE THE DOOR SWITCH. PRESS THE BUTTON IN WITH YOUR FINGER AND SEE IF THE LIGHT GOES OUT.
DOES THE SWITCH HAVE A POSITIVE CLICK? NO. REPLACE SWITCH. YES, THERE IS PROBABLY A THERMAL FUSE LOCATED SOMEWHERE NEAR THE EXHAUST. IT MIGHT HAVE FAILED. IF SO, THERE MAY BE A PROBLEM WITH OVERHEATING. THE MOTOR COULD ALSO HAVE FAILED. THE PUSH TO START BUTTON COULD ALSO BE DEFECTIVE.
Apr 07, 2008 | GE DPSB650EC Electric Dryer
The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
May 23, 2007 | LG DLE2512W Electric Dryer
Maytag MED9700S Electric Dryer Logo
99 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
