Question about Bush Bennington L-Shaped Desk WC65570-03
I have a blank page for step 4 and need to know what it says... pls tell me where I can find out what it should say.
Hello sir pls tell me how to change my belkin wireless password pls send me my e-mail add nilu_mehndiratta@yahoo.com
OPen Router Setup Page by typing 192.168.2.1 in address bar of any webbrowers like Internet explorer or Safari If you not able to Belkin Router Setup page through Webbrowser then,
Clicl on START>ALL PROGRAMS>ACCESSORIES>RUN
then type in RUN window http://192.168.2.1:80
Select Security
NoTe it may ask for password, by default no password so you can leave the box blank and then click on submit
Then Click on security (Towards the left pane)
Then select security as WPA/WPA2 vargheseacer_9.jpg
Then click on APPLY CHANGES
Now your N/W is secured Hope this will help you :-)
Dec 14, 2010 | Belkin (F5D7230-4) Router (587009)
I dont know my wpa
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left under wireless Click Security
Step 4 : If it asking for a password leave that blank and click submit
Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK "
Dec 05, 2010 | Belkin F5D8236-4 Router
I have a xbox 360 and there asking for a wep key where is that located?
Ill Help you in getting the wep Key From the Belkin Router
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the Left side , Underneath wireless click on security
Step 4 : If it asking for a password ... Leave it blank and click submit
Step 5 : On this page you can find the WEP Key ( Mostly the numbers on the Key 1 )
Tell me if it worked !!!
Sep 19, 2010 | Belkin (F5D7230-4) Router (587009)
How do i modify the settings on my router?
open internet explorer or firefox whichever you use. type in 192.168.1.1
or if that doesnt work 192.168.2.1 and iw will promt you wit a login screen most likely it well be admin admin as pw and login if not try admin *** the pw and leave te rest blank or try admin username password as the password or if u still cante figure it out let me know
or leave username blank and admin as the password
Apr 05, 2010 | Linksys WRT610N Wireless Router
When i turn on my laptop the screen blank as in
Please u replace the RAM which ur technician is notified & if u see the same problem then needed to change the HARD DISK.
ELSE Mother Board.
Jan 19, 2010 | Compaq Computers & Internet
When I print only a white page comes out, with no text. Do you know why this happens? It just started 2 days ago. It's not an inc problem.
STEP 1: Clean Print Head
The print head gets clogged due to frequent usage. Therefore, the ink will not be able to get out of the cartridge. Hence, the printer only prints blank pages. The solution to this problem will be to clean the print head. This can be done by cleaning it with a damp cloth or with an Iso Propyl Solution.
STEP2: Check if Cartridge is Empty
If this does not work, your next step would be to check if there is any ink in the printer cartridge. You might be giving a command for a high resolution printout, but the ink might not be enough for such a purpose. Look out for the printer prompts that will tell you about the low levels of ink.
STEP 3: Install the Correct Printer Driver
Many a times if you are downloading a printer driver from the internet, you might download the wrong driver. This will result in the computer not recognizing the printer. The result is blank pages.
STEP 4: Check for Appropriate Paper Size
Another facet to be taken care of is the printer size. You must check the Page Setup Dialog box whether you have selected the settings that are in tune with the paper size that is being used for the printing.
Jan 13, 2010 | HP DeskJet 9800 InkJet Printer
FACEBOOK PROBLEM BLANK SCREEN
hi this is kamal..
Perhaps you don't have java enabled. Please try the following steps:
http://www.java.com/en/download/help/enable_browser.xml
pls go through this link and let me know..
best regards
kamal singh
Oct 08, 2009 | Facebook Social Network
Yahoo mail is not opening
n my pc yahoo page is opening,but yahoomail link is opening.It shows page cannot be displayed.Pls reply me. no matter how i try i cant open my yahoo mail!! its just a blank page. I don't know what to do or what caused it!!
Feb 03, 2009 | Yahoo Mail
Bush Bennington L-Shaped Desk WC65570-03 Logo
23 people viewed this question
Top Bush Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Bush Furniture Expert? Answer questions, earn points and help others
