Question about Your One Source Homeline Load Center, 200 Amp
I have a 200 amp homeline loadcenter with a factory installed breaker and the code inspector is telling me we need a bonding screw however there is no tapped hole for a bonding screw
    Genius:
  • 1,198 Answers
I checked my code sheet, and only the ground bus is to be bonded to the box. The box comes with a screw that will bond the bus to the box through a bus mounting hole, the threaded hole is down there, behind the bus. The neutral does not get bonded to the box.
Posted on Nov 24, 2013
3 Suggested Answers
  • 760 Answers
SOURCE: I am trying to install
I'm assuming since it's a Homeline panel you're using a HOM2100 breaker. If it stripping then you must have a short circuit in your 100A circuit, or the breaker is defective. Disconnect your load from the breaker, and turn main on. Be sure you have the correct load conductors connected to the breakers. Typically red and black on the breaker, white on neutral bar. Bare to ground bar
Posted on Oct 01, 2010
  • 2006 Answers
SOURCE: can I change a 100 amp main breaker with a 200 amp main breaker on a homeline box
NO! The main breaker in each box matches the components of that box. Although it might fit, you are looking at a major code violation and possible fire danger. Which if you wanted to sell it later, could give you problems even if it did work and you didn't get have a fire.
Each circuit breaker box it rated to an amperage level and the main breaker is sized for that rating. Find the box tag and check what it is rated at.
Posted on Jan 17, 2012
Are HomeLine 20 amp circuit breakers the best for an average home?
not as far as I know we use square d around this part of the world .
Sep 01, 2016 | Your One Source Homeline Load Center, 200...
Are factory installed breakers already bonded
Get a letter from the manufacturer saying that the panel assembly and components meet all applicable National, State and Local codes. The inspector is an xss.
Nov 21, 2013 | Your One Source Homeline Load Center, 200...
I have a 200 amp homeline loadcenter with factory installed breaker the code inspector is telling me that it has to have a bonding screw however there is no tapped hole for a bonding screw. I read that...
For the neutral buss bar, a bonding screw goes through the buss bar into the box. Same for the ground buss bar. Usually, neutral does not meet ground until the meter, so there may only be a bonding screw for the ground buss bar. Look carefully, check with electricians.
I recently had new service installed. 200 amp load center at the top of my stairs, and a QOM2E2200NRB 200 amp enclosed breaker next to the meter socket. Idiot electrician bonded the neutral in the load...
Problem is not clear.
You have 200 Amp cut off by meter, with 3 wires from meter box:
2 Hot wires and a ground.
http://waterheatertimer.org/See-inside-main-breaker-box.html
You have 200 amp service panel.
Does the ground wire enter service panel from cut off box?
Feb 24, 2013 | Electrical Supplies
Can I change a 100 amp main breaker with a 200 amp main breaker on a homeline box
Jan 16, 2012 | Your One Source 100 Amp Main Lug Load...
How do i know which breaker goes where into my house.
If the installer didn't fill in the label inside the door you're relegated to turning one off and checking what turns off in the house. You can do this by yourself but it's a lot easier with someone in the house to tell you what shut off as you switch off each breaker in the box. Use things like plug-in lamps or hair dryers in outlets to know when they go dead.
Nov 13, 2010 | Your One Source Homeline Load Center, 200...
I am trying to install a 100 amp breaker into a Homeline 200 amp load center. Breaker flips every time main breaker is turned on.
Sep 06, 2010 | Your One Source Homeline Load Center, 200...
Subpanel hookup
Yes the maximum size branch circuit breaker that will fit in a residential load center is 100 amps. I would recommend that you calculate the amount of power that you need the sub panel to handle, then add any additional loads you may need in the future. Hopefully this is less than 100 amps. I would recommend that you check with your local electrical inspector to make sure your installation meets all local and national codes before proceeding with the install.
Dec 31, 2008 | Your One Source Homeline Load Center, 200...
Do i need to bond the panel frame to a grounded bus ?
yes but to frame ground only not the neutral buss as this is to stay isolated
Dec 06, 2008 | Your One Source Homeline Load Center, 200...
Your One Source Homeline Load Center, 200 Amp Logo
109 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
