Question about Xerox ColorQube 9201 9202 9203 Cleaning Unit 108R00841
Fault code 312.171.00
Paper jam in 4b
2 Suggested Answers
  • 2072 Answers
SOURCE: Fault Code 08.001.44 Paper Jam
That is a failure in the maintenance kit tray area.
1. The Cap/Wipe/Purge belts have loosened up or are out our alignment. - Adjust the Cap/Wipe/Purge belts and follow the procedures outlined in the Service Quick Reference Guide for adjusting these belts and proper alignment. 2. Ink contamination or spilled wax is keeping the Cap/Wipe/Purge from properly moving. - Clean up spilled ink from the drum maintenance rails guides, sensors, and pulley belts. 3. The Drum Maintenance rail guides are out of position. - Remove and reseat if necessary. These rails may have suffered fatigue and may show signs of cracking or breaking. If this is the case it is a recommendation to replace the Drum Maintenance rail guides
The maintenance drawer itself may have the end tabs worn down from lifting up and down.
Posted on Mar 27, 2008
What does Fault code 078-211 mean on Xerox copier D110?
Found in the Administrator's Guide:
078-210 / 078-211
[Cause] Tray 6 (HCF) malfunction
[Remedy] Contact our Customer Support Center
Before calling, check for paper jam or small pieces of paper in and around Tray 6. There may be a piece jammed around a sensor that is throwing the error,
Mar 17, 2015 | Xerox Office Equipment & Supplies
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
The Lexmark x342n all in one printer gives the error code 200.20 i took out the paper jam and tried to print again but it still gives the same fault i also can the drum and tried again but it only...
General tip: If the paper tears when you pull a jam out of the printer, spread the paper out and make sure you have all of the pieces. A small shred left inside can cause another jam.
"I also can the drum" - does this mean you discarded the printer cartridge? I've never seen a cartridge cause a jam. Usually an accordion-fold jam in this area is the result of the fuser rollers not turning or a torn fuser sleeve. A jam without an accordion fold indicates that the paper did not make it into the toner deposition area soon enough - this could be a problem with the pickup roller or the next set of rollers. Worn or dirty rollers can work intermittently before they quit completely.
Also, check the paper detection flag to make sure it isn't hanging up (this is a black plastic tab that sticks into the paper path just before the paper goes under the cartridge, and is pushed up or down by the paper). Look for the U-shaped optical detector that is interrupted by this flag, and make sure it isn't blocked by foreign material.
Jun 22, 2011 | Lexmark X342n All-In-One Laser Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
I am having a problem with my hp3210. It picks up paper but then shows jam . How would i know if the paper sensor is working
This is a common problem, Make sure the pick up rollers are clean (damp cloth and rub side to side) they may pick the paper but slip during the pick causing the paper to arrive late at the sensor. Check the fault codes or jam report from the information tab. If there are 13.1 jams, this is a good indication of the dirty roller problem.
Dec 21, 2010 | Office Equipment & Supplies
047-320 error
When we had this error code, we tried all the doors. No luck. I checked the fuser and there was a piece of paper jammed inside. We now know that we need a new fuser before the error message will go away, but it was the paper jam inside the fuser that caused the fault code. The fuser simply got too hot with the paper in there and burned up, apparently.
Dec 30, 2009 | Xerox Office Equipment & Supplies
Mar 27, 2008 | Xerox Phaser 8200 Laser Printer
Xerox ColorQube 9201 9202 9203 Cleaning Unit 108R00841 Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
