Question about Cerwin Vega LW10 Subwoofer
Cerwin Vega LW10 Subwoofer manual - Cerwin Vega LW10 Subwoofer
JULIANFIX
  • 975 Answers
SOURCE: Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Posted on Apr 19, 2008
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
Grubhead
  • 5484 Answers
SOURCE: my cerwin vega Lw12 subwoofer worked fine for
It sounds like the internal amp has failed. You could look inside and see if any of the main semiconductors has failed or blown apart!
Posted on Dec 15, 2009
SOURCE: Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Posted on Jan 31, 2010
  • 308 Answers
SOURCE: cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Posted on Mar 09, 2010
HI, I am trying to connect my cerwin vega xd3's to my pc (which works fine) and my Samsung LCD TV. I am not getting any sound out of them with the TV on. I have replaced the rca jacks and still...
The "audio jacks" on the rear of your Samsung TV are intended to connect TV audio to an amplifier. Your CV XD3s should be connected to the amplifier output.
Aug 10, 2013 | Cerwin Vega LW10 Subwoofer
I just pick up a used LW 10 Powered sub and 2 channel sherwood receiver.What is the preffered method of hook up up the sub with out a pre sub out?
"Sherwood Receiver" doesn't really tell us much about that end of the scenario.
Look at this picture of the sub amp.
http://cgi.ebay.com.sg/CERWIN-VEGA-LW-10-SUBWOOFER-AMPLIFIER-Speaker-Blade-Amp-/350444290153
You COULD run the Main speaker output to the large Red/Black speaker inputs, then some more wires Out from the other Red/Black connectors to your Main Speakers. That way your amp volume control will affect both equally.
Tweak the sub volume, crossover and phase to match it up to your mains.
May 15, 2011 | Cerwin Vega LW10 Subwoofer
My home theater base is pulsing constantly. Is it beyond simple repair?
Hi, you may try a simple repair by testing speakers continuity. Or do some board inspection and resoldering.
Feb 26, 2011 | Cerwin Vega LW10 Subwoofer
Got a cerwin vega cls 12s keeps blowing fuses. It has been well kept and all the connections are in the right place. It pop's before the light can come on. How do I fix, radio shack just down the road.
by the sounds of it the internal transformer could be duff. You need to take readings from the transformer using a multimeter to check correct voltages are coming out of the transformer to their destinations. I would also chek the capacitors and other components on the chain pre and post transformer to make sure none of them are damaged too.
IF YOU ARE NOT EXPERIENCED WITH MAINS ELECTRONICS DO NOT ATTEMPT THIS YOURSELF!!!!
Jan 07, 2011 | Cerwin Vega LW10 Subwoofer
Cant seem to find fuses that wont blow for my 10' re series speakers
if a fuse does not blow when a short is present then the wire or unit will catch fire. You have a dead short most likley in the subwoofer. If you unplug the subwoofer and the fuse does not blow then your unit failed.
May 27, 2010 | Cerwin Vega LW10 Subwoofer
Someone gave me a cerwin vega speaker, supwoofer, found fuse blown,this is a single speaker, lw-10, has electical cord, how do you hook up wiring on speakers?thank you
Pay really close attention to how the speaker is wired and make a written note, maybe a polaroid, even video, since it is a single speaker you hopefully will not have problems with the mess of wires.
May 01, 2010 | Cerwin Vega LW10 Subwoofer
No high output to the connected speakers
Speaker may be blown, pull it from the case and connect a spekaer wire you know is working to the sub, if no sound its blown. If sound then you have a problem with the connections or the sub pwer from the stereo.
Jan 22, 2010 | Cerwin Vega LW10 Subwoofer
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cerwin Vega LW10 Subwoofer Logo
99 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
