Question about Toys
Brio network characters - how do you replace the batteries in Freeze and Reboot?
I need a brio remote control. Can I buy one ?
Click on this link below and contact Brio for a replacement remote control to your express train
http://brio.knex.com/AboutBrio/Contact_Information.php
Aug 13, 2010 | Brio Remote Control Express Train
I don't have a Brio triangular screwdriver
The battery is easy to replace. The screw is located in the black "smokestack" and will require a small size phillips-head screwdriver to unscrew. The rest is easy--lift up on the black smokestack (I usually leave the screw in place), and the two AA batteries are located end-to-end in the body.
Oct 24, 2009 | Brio Mighty Red Locomotive
How to change the battery in Brio's mighty red action locomotive train!
If you look in the funnel there is a screw. Undo this and the front comes off and the batteries will pop out. Put in the new batteries and replace the funnel and screw.
Sep 17, 2009 | Brio Mighty Red Locomotive
Brio Mighty Red 512 - Battery help
Easy to do. You'll find a small phillips screw located at the bottom of the black smokestack. After unscrewing it, lift up the entire front black part and you will see two AA batteries inside the body of the locomotive. Careful not to strip the screw when replacing the black smokestack part, as it is the only thing holding it down!
Sep 11, 2009 | Brio Mighty Red Locomotive
Need to replace battery in brio big red engine
There is a battery down deep in the steam spout on top (black chimney type thing). Unscrew it and it slides off the front and allows you to insert 2 AAA batteries.
Dec 08, 2008 | Brio Polar Express Battery Engine
Contents of the Brio
Brio D-150 Zoom or C-1 Zoom camera, 8MB SmartMedia Card, (1) CR-V3 Lithium Battery Pack, Camedia Master Software, Win/MAC USB Cable, NTSC A/V Cable, Instruction Manual, and Carrying Strap.
Aug 31, 2005 | Olympus Camedia Brio D-150 Zoom Digital...
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
