Question about Black & Decker Garden
Brush hog BV4000
Need replacement carbon brushes for BV4000.
SOURCE: samsung washing machine carbon brushes (b1215j)
yes i have this carbon brush
how can i send u this carbon brushes .
where u live and from?
my e-mail address is
identity_ahsan@yahoo.com
Posted on Jan 30, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: How to change carbon brushes in Vax 2000
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. This is tricky but can be done.
Posted on Mar 31, 2009
SOURCE: The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Posted on Jun 17, 2009
Trouble with my bv4000 black and decker leaf hog.vacuum is weak and lacks power
Check and clean filter. If electric check brushes for proper motor operation. If battery is used, make sure it is charging properly. A bad battery will not work unit properly.
Sep 20, 2015 | Garden
I have a drill model ARPBD 1500. Set no 8161501. Can I buy a set of brush's for the motor.
yes the carbon brushes are available, you need to do a webseard with the make and model and the word brushes. my search found an auction on ebay so they must be available through the service centres that service your equopment
Jun 03, 2015 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Are brushes available for remington 106890-02
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Nov 06, 2013 | Remington Electric Chain Saw
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Need carbon brush replacments
google for sources. In the 80's i was employed by a co that probuced brushes according to specs. We received them in bags, or envelopes, etc. If you cannot find them through the orig. mfgr., send the remaining brush or the holder, with as much of the brush as is remaining for proper dim. estimate and brush composition. some brushes have the composition of dry charcoal. while some such as "EGO" can substitute for a very soft pencil.
Nov 26, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
BV4000 is electrically sparking in the upper part of the motor when running, looks like in/near the windings. Motor has slowed too. Seems hot.
The motor/armature is burnt. It will eventually fail completely. Many times too small a supply cord and too long footage length will overheat the motor. Anything over 25' should have a 12 guage power cord.
Nov 22, 2009 | Black & Decker Leaf Hog Blower Bv4000
Leaf Hog trouble
The carbon brushes wear out after a few years .B&D does not carry replacements . I took out one of the old brushes and found an exact replacement at an electronics parts surplus store . The replacement didn't have the little endcap on it so I used the ones from the old brushes and pigtailed the connector wire .
Its been working fine since !
Oct 22, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Garden Logo
27 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
