Question about Water Heaters
Potterton Boiler Manuals Performa 28, where can I get one
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
On Line.
Posted on Dec 29, 2013
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Hi. We have a potterton netaheat profile boiler and the pressure has dropped so low nothing will work. I know it needs to be recharged but don't know how to do it. The only visible pipes are on the top...
The cold water feed to the boiler is where you will find the refill point which should be at the base of the boiler where all the pipes come in
Oct 06, 2017 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
My potterton boiler ignites itself after turning it on then goes out
Assuming this is a combi boiler and you mean that the main gas burner comes on then off:-
How long after - 5-20 secs check overheat thermostat Check the wires to it are firmly in place i.e. making a connection. If Ok? then you can short this out by joining the wires together - do with boiler OFF at mains electricity
Longer - say 1-2 mins check secondary heat exchanger for blockage - usually furred up inside & only solution is replacement
Dec 22, 2009 | Water Heaters
Error code e133 comes up when flame ignites on boiler
the error code meant the presure are not above 2 bar see also pdf file manual on site http://www.potterton.co.uk/docs/Potterton_Promax_System_HE_Plus_LPG_User_Guide.pdf
Oct 31, 2009 | Water Heaters
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Water Heaters Logo
41 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
