AB Dick paper folding Model 58 - Office Equipment & Supplies
When opening the top, it all works until it is time for the truck to close and then it doesn't.
What make ,model an year vehicle ? Could be a sensor or a control module . Some of these convertibles are very complex , could set DTC'S diagnostic trouble codes .
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
DTC B367F 58: Roof Stowed Ready to Latch Sensor Circuit incorrect reaction after event
DTC B367F 59: Roof Stowed Ready to Latch Sensor Circuit circuit/component protection time out
DTC B367B 58: Deck Lid Anti-Rotation Latched Sensor Circuit incorrect reaction after event
DTC B367B 59: Deck Lid Anti-Rotation Latched Sensor Circuit circuit/component protection time out
Your best bet is probably to take your vehicle to a qualified repair shop.
May 23, 2016 | Cars & Trucks
Can a paper folding machine fold paper of different sizes or do they only work with standard size paper?
Most higher end folding machines are able to fold most standard size sheets of paper. You would have to check the manual or with the maker before trying anything too fancy. Mine works great with A4 and standard 8.5 x 11" papers.
Sep 24, 2013 | Office Equipment & Supplies
What is a paper folding machine?
This is a machine that folds papers or letters instead of you folding them all by hand. It can fold statements, invoices, brochures, etc. It's really useful for businesses. It can fold about 1800-18000 papers in a single hour.
Jan 17, 2013 | Office Equipment & Supplies
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
Paper folder grabs too many sheets and doesn't fold accurately
Not sure what make / model you have but folders are pretty much the same. The issue with the paper feed is your retarder, also known as the paper seperator. On the feed table where you load paper there should be a pad or rubber wheel. Look for an adjustment screw. You need to close the gap enough so that it only takes one sheet at a time. The extra fold sounds like you need to adjust the fold plate stop positions just a hair. If you give me the make and model I should be able to email you a manual.
Apr 10, 2009 | Office Equipment & Supplies
Code for box
29.novN*l
0=CD 11 58 05 EE 96 E7 F3
1=EA B7 BF B2 D5 AA 46 AB
tw.
0=98 B0 BA 52 D3 21 08 B4
1=D2 EA 29 B7 B5 52 E9 AD
cw.
0=00 58 8D CF 27 98 04 ED
1=2A E0 72 B0 9E 07 9B 5D
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes for ntl cleveland
LOST CHANNELS ON EUROMAX BOX
N*l
tw
cw
Need codes for starview3 ntl plz
Math
x+1/x=2cosa let find the value of 13x+12/x
Jul 24, 2008 | Computers & Internet
54 people viewed this question
jasbo
jasbo
