I have a problem with sansui amplifier rz-5100av when powered it just writers protector
4 Suggested Answers
SOURCE: Sansui RZ 1500 II-Manual
i have the same problem but my receiver doesn't change sources and its blocked on the last station llistened. the problem appeared when i washed the face of the receiver with a special spray. i think that i have done something very wrong like a short cut in the command processor. any help, please?
Posted on Nov 08, 2008
dunnbiker
  • 8546 Answers
SOURCE: Sansui Amplifier RZ 7900 The surround
I can't find a manual but I'll take a stab.
When you say it fades are you being literal? In the digital world things usually change suddenly or stop altogether.
I'd look at the receiver for an indicator that indicates the multichannel nature of your incoming digital audio. Many have little maps or icons showing the number of speakers supported at any given time. That's a function of the incoming data stream and/or whatever the audio source it carries. For example, when loading a DVD I usually see 2.1 indicated on my unit while the low-tech menus and previews are active. Once the multichannel program commences the 5.1 indication lights up.
It almost sounds like the digital bitstream is being corrupted and the receiver shifts down to whatever it can manage to decode from it. Check the cabling that carries the audio. If it's optical instead of copper, I'd check to make sure there are no tight bends or kinks in it anywhere.
Posted on Dec 23, 2010
dunnbiker
  • 8546 Answers
SOURCE: Please let me know the
http://www.springair.de/Sansui-RZ-3000_detail_13525_326_SESS-51aeaa5f0105cfe40d86469ac9c7cb85.html
In German but it says 2x80 watts. I'd guess 1980's.
Posted on May 28, 2011
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Aug 17, 2011 | Sansui RZ-5200AV Receiver
I have a 1975 Sansui Integrated Stereo Amplifier and Left Channel on System A & B are faint and Tinny as if Left Channel in System went out. I swapped speakers from right to left channel and same...
It's likely there is a fault on the power amp. This is located on the heatsink. A visual check inside the unit might be what you need. Look out for blown parts, bulging capacitors or burnt components. Remember the two channels are generally separate and identical. So identify the two channels. Work back from the speaker sockets if you can't tell. Then compare the left channel parts with the right side components. If it looks odd on the left compared to the right you have found the problem.
Feb 14, 2018 | Sansui RZ-5300AV Receiver
I have a Sansui receiver Model RZ-1000. The left channel is out. Cheaper to repair? or just buy another similar on ebay?
I have this unit. It is built with disable links for each of the channels, which are easy to replace. The replacement part is only a few dollars.
Oct 11, 2010 | Sansui RZ-5200AV Receiver
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
RZ-8903AV no output
Audio amplifiers IC´s damaged
Mar 16, 2009 | Sansui RZ-8305AV Receiver
122 people viewed this question
 Grubhead
Grubhead
