Question about AM Auto Parts 1996 to 1997 Ford Taurus SHO Air Flow Meter with Housing for V8 3.4L
Why is rear fade is not working.
Car has 51000 in beautiful condition. Radio works great but the fade for the rear speakers will not let them come on at all. It has no visible speaker wire damage. I want to know is there some test I can do to see if they are getting voltage? and if there is a fuse or a specific harness that may be unplugged under the dash.
    Top Expert:
  • AM Auto Parts Master
  • 41,853 Answers
If the indicator moves but you do not hear sound from the rear, there may be an internal failure in the radio. If the rear speakers have never worked, they may not be connected or some connection has come loose. Check the balance setting and any other adjustable setting you may have that could be be set all the way one way or another. Check the connector on the rear of the radio to be sure it is completely engaged.
Posted on Nov 22, 2013
Sears customer service
Call a Sears service center near you or get the information from a local Sears store. They will generate a service tag and get it fixed for you.
Oct 30, 2017 | Sharp CV-2P12SX 11,500 BTU Portable Air...
Engine failsafe program light
no ---you have a problem so run the fault codes to find out what it is
then use a scan tool to reset the ECM
Feb 16, 2018 | aFe 2001 BMW 7-Series - 740iL, 4.4L V8 -...
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
I have cleaned the unit thoroughly and the red cleaning light will not turn off on the ionic breeze quadra. what can i do? I bought this on ebay==never again?
blast bottom of unit with high pressure air from oxygen bottle. Wife has copd. Is on oxygen and I used her high pressure bottle. Works great. Unit works great.
Jul 14, 2010 | Sharper Image Professional Plus Ionic...
I have a sharper image midi and the red light (cleaning overdue)stays on even after cleaning? Will it still work with the light on? My real question how to fix it
Same problem : after cleaning thoroughly inside by removing the Front& Rear Plastic grid and the stainless blades, I also cleaned the 2wires (very softly and carrefully, not to break them), but the Redlight goes on after only few minutes :
Here is my Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no more Red light. Maybe it will work for you. I also found this other bit of information. Since then I have discovered a lot of information on the midi. Here is some more reading material that might interest you.
Could be a blade replacement needed but Sharper Image2.gifrecalled the product. Since it was proven in court that it wasn'teffectively cleaning the air by Consumer Reports as well as EPA data. As a result of the legal action, Sharper Image filed for Chapter 11.
Here are a few links about it:
http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
http://www.epa.gov/iaq/pubs/ozonegen.htm
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commissionis going to be making a decision on ionizers at the end of year sincethere are hazards in the air from using the devices. It could be thationizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it. The next step to do if you can't get it to work is to file a report with the company.
The Ionic Breeze would work for a short time after cleaning and the bluelight would start flashing again. We checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So we went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. The Ionic Breeze produces harmful Ozone gas, so we don't use it anymore.
Best wishes. Hope this helps you. If not please leave me a comment and I will do some more research.
Aug 22, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
My ecoquest breeze is squeaking
Singer sewing machine oil works great. Remove the front grill and carefully remove the fan by sliding it off the shaft. Where the shaft meets th4e motor, place three or four drops of oil. Spin the shaft and wipe off the excess. Place the fan back on the shaft, flush with the end of the shaft. In the rear, remove the lint screen and the ozone plates. Put oil on one end of a Q-tip over a trash can until it drips off. On the rear of the fan motor, push the Q tip against the shaft so that oil oozes out. Again, spin the fan. Repeat this process every time you clean your Breeze and it should never squeak again.
Mar 25, 2009 | Ecoquest Breeze AT Living Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Lamp replacement???
Make sure the lamp is seated properly. Take it out, put it back in, turning it back and forth until it clicks. DO NOT TOUCH with your bare fingers.
May also need to replace the starter (the aluminum can at the rear of the unit).
Jan 20, 2008 | Ecoquest Fresh Air Air Purifier
AM Auto Parts 1996 to 1997 Ford Taurus SHO Air Flow Meter with Housing for V8 3.4L Logo
29 people viewed this question
Top AM Auto Parts Air Purifiers Experts
David Payne
David Payne
ray gallant
Are you an AM Auto Parts Air Purifier Expert? Answer questions, earn points and help others
