Question about Heavy Machinery
RYOBI RGS 2000
Ryobi 2000 watt gen is leaking fuel into air cleaner.
Most common for a unit that has been setting with fuel in the carburetor to have varnish around the inlet needle, so that it is sticking and not turning off the incoming fuel. Suggest you disassemble and clean the carburetor, and replace any damaged parts.
Feb 23, 2017 | Ryobi Garden
Ryobi RESV-2000 electrical failure (will not start)
If all the obvious shows nothing wrong, wiring, connections, etc ok, use a multimeter to see if power is getting to motor. If so then most likely one of the windings is broken.
Feb 24, 2014 | Ryobi Garden
Ryobi how to
All bearings today are factory sealed and are not greaseable, at least in this country. I really doubt Ryobi makes a greaseable bearing on anything they manufacture. Be blessed.
Jan 13, 2014 | Saws
My ryobi T430 will not get to desired rpm
Do you live at higher altitude (above 2000')? I live at almost 5000' and had the exact same problem. The trimmer wouldn't reach full RPM, and would actually lose RPM if you tried opening the throttle full. The manual says that if you live above 2000', you need to have it adjusted by a technician.
May 22, 2011 | Ryobi Garden
Hi my father is looking for spare parts for his ryobi rgs-1500 in new zealand and is having a lot of problems. where can he get V blade (ref bin 12), shredder blades RY6250 200001 (REF 10), cutting plate...
Kia ora
Been having the same problem myself. After much trauling of the internet the only source I have found for RGS1500 spares is at the link below. A company based in the UK which also provide International Delivery.
http://www.mowermagic.co.uk/acatalog/Shredder_Blades_for_RYOBI.html
All the parts you have mentioned are listed.
Apr 10, 2011 | Ryobi Garden
Laverda RGS 1000,Veglia revcounter repairs
Laverda specialists such as Wolfgang Haerter; OCT or Andy Wagner/Laverda Paradies can help. Some enterprising owners have replaced the electronic guts with an aftermarket unit whilst retaining the original housing.
There are a couple of possible causes to consider - duff electronic revcounter or aftermarket (DMC) electronic ignition fitted which needs a filter fitting to the revcounter wiring - again, the latter is obtainable from Laverda specialists. Check out Laverda forums such as www.laverdapedia.com/forum for more info (use the search facility)
May 23, 2010 | 1987 Laverda SFC 1000
Installed RGS on Dell (Sender), Reciever is HP machine. There is a problem in connecting Dell machine by HP machine remotely, where as If the Sender machine is HP then its no Problem. While Installation of...
The reason is that RGS supports only HP machines as sender. Take a look at the data sheet under "Sender support matrix". A receiver can be almost any machine running Windows XP, Vista or Linux.
They just don't want you to transfer the software to other systems...
Oct 24, 2009 | Computers & Internet
DCS RGS 366 range, oven will not do anything when I turn it on
Sounds like the electronic ignitor has gone bad. Here is DCS contact info, they should be able to direct you to a reliable service provider:
contact DCS Customer Service at (888) 281-5698. Before you call, please have the
following information ready:
 Model Number (located on rating plate backside of kickpanel).
 Serial Number
 Date of installation
 A brief description of the problem
Your satisfaction is of the utmost importance to us. If a problem cannot be resolved to your satisfaction,
please write, fax, or email us at:
Write:
DCS
Attention: Consumer Relations
5800 Skylab Road
Huntington Beach, CA 92647
Fax us at: (714) 372-7004
email: support@dcsappliances.com
Oct 16, 2009 | DCS RGS-366 Professional Gas Kitchen Range
My oven won't heat up and just smells like gas but my stove burners work
Hello, This is going to be a problem with your igniter/glow bar. Over time these get old and although you may see it glowing iit still may be bad. Your igniter should glow a brillient yellow and should ignite the gas within 15 seconds of the valve opening. If you have any other questions or concerns please feel free to comment again...Good Luck! Mike
Aug 17, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Heavy Machinery Logo
55 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
