Question about Dell 305-watt Power Supply For Dimension/optiplex l305p-01, Nh493
Power switch connection for Dimension/optiplex l305p-01
Question about Dell D220P 01 Optiplex AC/DC Adapter 220-Watt Power Supply HOW DO I USE THIS UNIT TO PROVIDE 12V STANDALONE POWER?
most power supplies have a switch for 120 and or 220 options just move the switch to what setting you want. most power supplies can be used as a stand a lone power supply, if not than you need to request for a 220 watt power supply the can be used as a stand alone for pc or computer use. most computer retail should have them in stock. look on line or at
www.fryselectronics.com/computer/parts/power_supple/stand-a-lone/for_PC_use/220_watts/
type power supplies stand-a-lone 220 watts computers compatible
Mar 02, 2015 | Dell D220P 01 Optiplex AC/DC Adapter...
We've got a dell dimension 4600 that won't power up. It was doing ok and then was left for a few days and wouldn't turn on. The green light on the mb is on but no lights on the back and nothing at the...
I would try clearing the bios, and also checking the caps with a multimeter that reads uf. Some caps can die without buldging or anything. Another thing to try, is manaully jumping the on switch to see if its just the switch.
Sep 10, 2013 | Dell OptiPlex GX620 PC Desktop
Main power button LED is flashing or solid yellow
This is a major problem that crippled Dell. Moels Optiplex Gx260, Gx 280, and Dimensions of whose mdel number i don't remember have this problems. This signal shows that either a power supply or your motherboard is malfunctioning. If you have an insurance better use it now or else get some technical assistance.
Nov 03, 2009 | Dell Dimension 8200 PC Desktop
I mistakingly switch the voltage to 110v instead 230V
You are going to have to replace it....obviously. Here are some places that popped as having the supply you need. I have never used any of them personally.
Dell Optiplex Gx1 Gx110 145w Desktop Power Supply 5554t
$14.99 used - eBay Dell 11VTW Optiplex GX110 SFF 110W Power Supply (See 1728P)
$35.00 refurbished - Used-pcs.comNEW Dell Dimension XPS OptiPlex Power Supply, 200W, Dell 824KH
$19.97 new - TXcess Surplus
Oct 07, 2009 | Dell OptiPlex GX110 PC Desktop
Front Panel help for Dell Dimension 4600
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Jun 17, 2009 | Dell OptiPlex 170L PC Desktop
Dimension 2400 can not power on
If you have no power by pressing the front power button and you have verified that the black connector coming from the power switch on the front is connected properly to the motherboard, then make sure that both connectors from the power supply are connected properly, the main connector and the p4 connector. Reseat both of the connectors to be sure.
If you still have no power and still have the light coming up on the motherboard then I think the motherboard may be bad cause that means something is shorting out the motherboard and not allowing power to go thru it properly.
Mar 08, 2009 | Dell Dimension 2400 Power Supply ** FREE...
Motherboard having a system password , idonot know what is its pa
Open the case and look for a jumper switch (usually blue or black color) labeled CLRTC or CRL. A jumper switch is a small connector connecting two pins on the motherboard. Same like the one in CD ROM drive or hard drive for selecting master or slave.
If you find it, unplug the power cable, remove the jumper. Wait 10 - 15 seconds, then put it back. Plug the power cable and try power up your computer.
Dec 25, 2008 | Dell Dimension 2400 PC Desktop
Dell 305-watt Power Supply For Dimension/optiplex l305p-01, Nh493 Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
