Question about Water Heaters
Ideal mini c24 won't light
Intermittant fault, works fine, then doesn't. Lights at the bottom, first flashing green, no other lights on. Turn on the tap, lights one and three flash green alternatively, but no pilot light, no heat and no hot water, sounds like it's trying to light, but nothing happens
2 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: hi, my ideal combi boiler mini HE C24 has lights
could be your microswitch check overheat stat and fan are o.k. best of luck
Posted on Oct 21, 2009
Pilot does not ignite?
Look for the pattern of flashing lights when it fails after you turn the power off/on. Then look at the wiring diagram / instructions on the inside of the panel. The flah pattern should be listed. For example, two green flashes and pause, repeating may mean that the exhaust flow is not sufficient, or another flash pattern may indicate pilot is not lighting.
Likely ly a pressure switch is bad or exhaust is blocked.
May 17, 2015 | Water Water Heaters
My water heater pilot light won't stay lit
you need to clean the filters in the bottom of the water heater and have the thermal couple also check and see if there is a gas leak by spraying all visible gas lines if this doesent work then you more then likely need a new watter heater
Jan 17, 2012 | Water Heaters
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
Missing instructions for setting timer on boiler
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
Feb 21, 2009 | Water Heaters
Stiebel Mini 4 won?t activate using 40l/min pump
You have to make sure that the pump is flowing enough water to activate the Stiebel. The tankless unit has a activation rate of a certain amount of water to turn it on.
Jan 18, 2009 | Stiebel Eltron Mini-4 Tankless Water...
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Ideal c24
Call the manufacture at 800-432-8373. They will be able to assist you. Have your model & serial number. Parts may be under warranty.
Oct 14, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Ideal c24
Hi Jurgie,
I'm Harvey, the Master Plumber,
Happy to render my assistance.
This is your problem!
When you are switching on the boiler it ignites for 8 to 10 seconds, then it cuts off and the lock out lamp comes on. Pressing the reset button or turning on the hot water tap has the same effect.
I need to get the make and model of your specific boiler to give you an accurate answer!
Waiting for your response.
Harvey, your Master Plumber.
Sep 07, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Water Heaters Logo
79 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
